#21 |
It is soft but it does work OK. You need to drop subframe down slightly to clear the battery, and remove part of the tank hinge.
#22 |
Thanks for all the help guys, think I will keep an eye out for a cheap 636 shock as this generally seems to be the most popular and the most straight forward to change.
#23 |
Yeah for that you need to chop the battery box a bit, raise the battery a bit, and lose the fusebox tray.
#24 |
I also chopped the tank hinge thing when I did my zx10r shock for poos and laughs.
Smokey Black Burnty 02 - Racetech Smoulderlators + .90kg BBQ Springs, zx10r shockingly toasted, Conti Road Attacks heat up very nicely, R&G Crash Bungs but what f**king use are they, No Colour Matched Hugger, Flame Extenda, Beowulf Titainium Oval Flame Thrower. |
#25 | |
#26 |
#27 |
Don't discount a ZX10-R shock, as Britney correctly stated, they have same spring rate as the 636 and you may get a newer one. I managed to get mine with less than 50 miles in it from a racer who was replacing it with something exotic.
#28 |
Does anyone have any further info on fitting the ZX6R shock? I've just received a nice low-mileage one and plan on fitting it when I do my forks and brakes. I've searched and searched and it looks like you either cut the battery box and move the battery or move the whole battery tray and undertray back by making new mounting points? Anyone got any pictures?
#29 | ||
so if your fitting Hagon progs, have you thought about matching the rear with a hagon shock?. It worked super for me, transformed one of mine tremendously, even my chap was surprised at the difference. Its plug n play after all, no need to chop anything, and they work exceptionally well in tandem. I got Pete n Lissas first shock under the bed for 25 quid, its only got around 1500 miles on, I thought that it would be worth a go, as the old ones like a pogo now and stressing the front end out on Dave too much, hopefully it will be fitted in next week or two....fingers crossed
Suzy, yellow 2001 SVS. Kitty, V-Raptor 1000, ZZR1400<<its my bike now Pegasus! Hovis 13.8.75-3.10.09 Reeder 20.7.88-21.3.12 |
#30 |
Cost is the big factor against the hagon, it's not that different to standard. Has anybody properly abused one to see if they still boil and get all out of shape?
It's 5x the cost of a used one from another bike. What we need is for someone to make some SRAD shocks into remote reservoir ones with a harder spring and damping to match.
Rear shock 03-08 | silent11 | For Sale - SV's and SV related items | 0 | 17-05-08 02:53 PM |
rear shock nut and bolt for a diff shock | drag | Stuff Wanted | 0 | 22-04-08 03:52 PM |
rear shock | socommk23 | Bikes - Talk & Issues | 1 | 23-04-07 05:09 PM |
Rear shock | latts650s | SV Talk, Tuning & Tweaking | 1 | 09-08-05 09:17 AM |
Rear shock | sprocket | SV Talk, Tuning & Tweaking | 3 | 17-05-05 10:50 PM |
