Old 13-05-09, 12:18 PM   #21
AndyBrad
Default Re: bike wont start. Again !
Originally Posted by vardypeeps View Post
Disconnect them from your loom/battery and find out. They might be bust and still drawing power
Also letting a bike idle for a log time actually drains the battery as it won't be getting enough revs to charge.
You should come for a run up on the moors with me and give it a good run out now and again.
aye up for a run in a couple of weeks if you fancy
Old 13-05-09, 12:21 PM   #22
vardypeeps
Lets all help getting you sorted then!
I'm guessing chris is going to say test the voltage etc with a multimetre but I don't know what they should read when you test the connection etc.
You been out and about locally to try any of the roads?
Old 13-05-09, 12:39 PM   #23
AndyBrad
In the other thread i tested it and it seems to be ok (well no one commented)
Old 13-05-09, 03:40 PM   #24
Biker Biggles
Biker Biggles's Avatar
4 miles isnt enough to replace the charge you use to start the bike,so every time you use it the battery will get a bit flatter.You need an optimate and it needs to go on charge at least once a week if not more.Did you ever fully charge your new battery when you got it?If not it will never work properly and could well be shagged by now.It may be worth getting a multimetre and checking the system again,as all the faffing about might have caused the reg to fail now.
Old 13-05-09, 03:45 PM   #25
AndyBrad
How can you put it on an optimate when its outside and we have weeks worth of rain at a time?
Battery out job or a simpler solution?
Old 13-05-09, 03:59 PM   #26
slloyd
You will need to remove the battery and get it on an optimiser. I had the same problem with my bike when I purchased it, kept cutting out. On putting it on an optimiser for 48 hrs, it charged it up to 14.3volts - placed it back on the bike and all was well.
Old 13-05-09, 04:12 PM   #27
Biker Biggles
Extension lead?Charge it at work or somewhere else?.It doesnt need to live on one but a full charge once a week will keep the battery maintained.
Old 13-05-09, 04:17 PM   #28
It's a waterproof connector with only 12v going through the wire, just run it out the edge of window or something.
Old 13-05-09, 04:20 PM   #29
ophic
ophic's Avatar
I've always charged indoors - just whip the battery out. I had a similar problem with a car being underused and so when i bought a new battery, i kept the old one on a charger indoors. If it didn't start - just quickly swap the batteries over and away you go.
Silver SV650SK3, Fuel exhaust
Old 13-05-09, 04:35 PM   #30
Nowthen.
Im commuting 4 miles each way. So would that be an issue? And yea the batterys new.
I can garantee this is the problem. Had far too much experience of this
The zapper pack. Is there a way to connect these to the bike without taking the seat off?
yep, red on starter motor bolt, under the rubber boot next to it. Black on bolt on frame
My worry is also that ill get caught out on a rideout? Not if you've done a good run a day or two before
Whats this about the regrec? I took a lok last time and it appeared to be charging ok. (other thread) is there something else to look at? And whats the switch?
Clutch switch a bit more complicated, dunno!
BTW, I don't have an optimate, can't be arsed with one, I learnt my lesson with flat batteries far too often, so go the long way round to work, and make a great effort to go out and bloody ride the things when I get a good chance.
non starter richiekuk SV Talk, Tuning & Tweaking 41 22-05-09 01:49 PM
Non Starter slloyd SV Talk, Tuning & Tweaking 3 01-03-09 03:11 PM
non starter evertheoptimist SV Talk, Tuning & Tweaking 9 09-05-08 06:19 AM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
Non starter - help sticky-dizzle SV Talk, Tuning & Tweaking 11 12-04-07 02:38 AM
