Old 05-06-09, 12:44 PM   #21
Default Re: just fitted a double phone charger
ta ...
again..
Old 05-06-09, 12:45 PM   #22
Put fuse as close to battery as you can. This means switch after fuse.
Old 05-06-09, 12:47 PM   #23
COOL.. TA CHRIS TOO..
oops caps, fat fingered freddy .
I have already put fuse close to battery on monkey advice earlier. which means it under riders seat.. sonow hopefully can put switch up under the pillion seat next the the charger unit.
oh my god.. I got to fit my autocom yet too.. and a scottoiler.. lol
Old 05-06-09, 02:00 PM   #24
all done all working..
switch under pillion next to the socket.. what a pain though.. was a coiled wire! with them fused together ha.. and I had already thread it through from front to back so had to take it all out and follow the live wire down... actually probable made it easier doin it on the bench then feeding it all back through..
didnt get a
marine switch.!! but put some heat shrink on and then some almalgamting tape loks a neat job.. will see what happens if it rains.. and when I wash the bike.
thanks all..
now got to find where my switch live to the rear light is ............. to and the autocom....
Old 09-06-09, 11:23 PM   #25
update- autocom done ! wow its ace
Old 26-12-09, 10:14 PM   #26
cbay
cbay's Avatar
Quiff Wichard, have you got any pictures of your socket install?
Old 27-12-09, 05:18 PM   #27
Personally, i would have put a relay in working off a switched live off ignition, cant go wrong then, same for cars, boats or whatever.
Will only work when ignition is on and relay will control switching of it.
Here's a link to my thread regarding mine.
http://forums.sv650.org/showthread.php?t=137700
Old 27-12-09, 09:37 PM   #28
Sally
http://forums.sv650.org/showthread.php?t=132481&page=1
Have a read throughthat, lots of good info.
Pictures of my set up on page 3.
Enjoy and Good luck.
Old 28-12-09, 01:18 AM   #29
Ploppy
i appear to have found this thread a little late but here's for any one wanting to install electrical gadgets the bike, take a look through the following....
http://www.powerletproducts.com/
basically you can install a power let point or cigarette lighter connection to the bike, which means anything from a sat nav to heated clothing to a phone charger can be simply plugged in and run off the battery if it has the connection. Since buying the sprint ive found it has a power let point fitted as standard which is handy just bought the adapter to plug my battery optimiser straight into the power let point, which means i can charge the battery without messing arround with taking the seat of and fiddling with crocodile clips
HPH
Old 28-12-09, 07:32 PM   #30
jimmy4237
I've one on my 9R Kwak. I used it to power air pumps for blow up beds whilst camping, charge up mobile phones, and have constant 12v power for my bike camcorder when in use. Every bike should have a 12v accessory plug as standard.. very handy item.
Mine is constant 12v all the time wired to the battery, with the live via a 10amp blade fuse located near the battery. Hasn't blown one yet.
One shall be going onto the hack bike shortly for my heated vest when it's cold in the mornings or night time running...
Battery Charger chris_c201 SV Talk, Tuning & Tweaking 2 20-04-09 10:56 AM
Double bubble just bought and fitted ... Tony_BLY SV Talk, Tuning & Tweaking 11 30-05-07 10:15 PM
Battery Charger 600+ SV Talk, Tuning & Tweaking 15 22-01-07 03:07 PM
Anyone fitted an MRA Double to a K5? independentphoto Bodywork 2 20-03-06 04:33 PM
Which Battery charger should I buy? Mark_h SV Talk, Tuning & Tweaking 20 19-12-05 10:37 AM
