Old 30-08-09, 10:08 AM   #21
AmigaNut
Default Re: A knack to starting it?
Its a charger/maintainence unit.
It will chechk the state of the battery and tell you if its ok or knackerd.
Also when the bike is not used for weeks it will maintain the battery so it's always tip top.
Needs a power point but you can get extension leads to add on to extend the range from the charger to the bike and comes with permanent on bike weather proof connectors.
There are various makes from about £28 upwards.
http://www.optimate-chargers.co.uk/?...FYIA4wodBhXoHg
above as an example, but I think it's a bit expensive on that site.
Old 30-08-09, 10:12 AM   #22
Dizeee
So next question, how on earth does one get to / molly coddle the battery?
Old 30-08-09, 10:19 AM   #23
AmigaNut
Just leave the optimate on when not in use for more than two weeks, if it tells you the battery is OS when you fisrt set it up then you need a new battery and go from there.
Old 30-08-09, 10:54 AM   #24
sam anon
You're not trying to start it with the lights on are you?
Old 30-08-09, 10:56 AM   #25
lee67
cant turn the lights off on a pointy dude......as already said chances are the batt is either duff or just short on charge due to been sat in a dealers....ride the thing and it should be fine, of course an optimate works wonders too
help with starting - YC scottjames SV Talk, Tuning & Tweaking 20 10-10-10 04:51 PM
Not starting Ben Flanagan SV Talk, Tuning & Tweaking 4 27-08-08 07:57 AM
not starting frankie77 Bikes - Talk & Issues 0 15-08-08 05:51 PM
SV not starting Draper SV Talk, Tuning & Tweaking 21 27-09-07 02:20 PM
Help starting up Spewy SV Talk, Tuning & Tweaking 8 03-04-06 12:07 PM
