#21 |
Because its probably got a better chance than boiling water
#22 |
surely that's gotta be why.
Silver SV650SK3, Fuel exhaust |
#23 |
Boiling water will cause the cap to expand[1], ideally expanding enough to free off what is presumably the corrosion attaching it to the stem. Using a naked flame is either asking to be burnt, set fire to the stem, blister the paint or all three. WD40 as previously stated is *not* a penetrant so will do virtually nothing unless there was little wrong in the first place. BTW that test was after *soaking* the parts for 8 *hours*.
Druid [1] I'm not sure what the metal the thread on the valve is made from but I presume either steel or maybe brass, both of which have a lower Coefficient of Thermal Expansion[1] than Aluminium - http://en.wikipedia.org/wiki/Coeffic...rmal_expansion
'00 SV700S - '94 RVF400R - '97 RVF400R - '88 VFR750F |
#24 |
Looking at the picture it seems to be cross threaded-----let the tyre down, break the rim seal, cut the old valve off and fit a new one and blow the tyre back up to the proper pressure.
Apart from the MOT Examiner being able to refuse it is dangerous to ride if it is so under inflated that you are worried about it passing the MOT. |
#25 |
Virtually nothing or nothing? There is a difference.
And yes tyre valves are typically made out of *Brass* |
#26 |
ive seen people loctiting these on so they cant be nicked bit stupid because then you can get the proplem uve got. proberly have to get the valve changed
#27 | |
That's what the man says and he knows better than I. Don't fancy doing a test either before some wisearse suggests it. Garry ![]() |
#28 |
wasn't cross-threaded, was just corroded in place, new valve on it and MOT passed
#29 |
At least when its stuck on no one can nick them
#30 |
Another one bites the dust. | Conrad Poons | The Essex Lounge | 19 | 23-04-07 07:29 PM |
Dust Seals | TSM | Bikes - Talk & Issues | 5 | 01-09-06 10:10 AM |
another one bites the dust... but it doesn't put me off. | GooseSVSK2 | Bikes - Talk & Issues | 18 | 13-05-05 12:30 PM |
another one bites the dust... but it doesn't put me off. | U.K.Ajay | SV Talk, Tuning & Tweaking | 11 | 04-01-70 03:40 PM |
