#21 |
quick and easy test switch ht leads from front to back and back to front to see if it switches if it does test ht leads for continuity
#22 |
Trinity
Don't forget - which exhaust pipe is heating up will tell you which of the 2 cylinders is working.
#23 |
#24 |
Do what i told you the other day
Whip front plug cap off, unscrew it from the ht lead, dry both out, cut about 5mm off the ht lead, put vasaline in where the ht lead screws into the plug cap, put the wterproof cover back on, screw ht lead in, clean the drain hole on right hand side of cylinder, i also put a bit of vasaline in the other end off the plug cap what plugs onto the sprak plug and put it all back together and bobs you teacup, alright ice cream cone ![]() ![]() |
#26 |
Great advice guys (of which I have no idea what you just said), really great, thanks.
![]() Will pass this onto Chris and pray that when I come home from work on Saturday that my little Suzie will be running fine again ![]() |
#27 |
#28 |
i'll go for the connector plug under the clocks. the one you disconnect to take the top fairing off.
#29 |
Trinity
#30 |
Trinity
Loss of power, now no go at all. | jnr-biker | SV Talk, Tuning & Tweaking | 8 | 22-11-09 10:50 PM |
Power loss!! | chris8886 | Bikes - Talk & Issues | 12 | 01-12-07 12:56 PM |
Unusual loss of power | JimmyGulp | Bikes - Talk & Issues | 6 | 23-01-07 05:50 PM |
Power loss? | FreshAL | SV Talk, Tuning & Tweaking | 6 | 02-03-06 11:18 AM |
Loss of power..... | Nekkid | SV Talk, Tuning & Tweaking | 16 | 21-10-04 05:00 PM |
