Old 22-11-09, 10:17 PM   #1
jnr-biker
Unhappy Loss of power, now no go at all.
im a newbie to bikin. i bought my first bike its an sv650.. bike ran perfect for first month. then one day it only gave half its power???? then back fired i made it home with out this happening again but when i started the bike back up shortly after it died every time i pulled the throttle and since hasnt started any body know why this would happen?
Old 22-11-09, 10:29 PM   #2
warrenhewitt10
Default Re: Loss of power, now no go at all.
wot year is it?
Old 22-11-09, 10:31 PM   #3
jnr-biker
its 2000
Old 22-11-09, 10:38 PM   #4
thefallenangel
was it raining?
Bike could of single cylinder'd (water in front plug causing it to fail),
Check your normal checks first (Oil, water, leaks etc . . ). If all okay then start looking towards front plug and clear out with WD40 and either invest in a fender extenda or try some sealant around the front plug.
Old 22-11-09, 10:43 PM   #5
jnr-biker
sorry but im new to all this. how do i get to the plug. ido i have to remove the radiator. it was rainin when i was ridin but its been 3 days and the bike hasnt started
Old 22-11-09, 10:45 PM   #6
thefallenangel
my advice is check the oil first as it's just a tell tail sign if anything is wrong, any clanging noises when it cut out? And also if the front plug has water around it, clear it using WD40 with a straw and you shouldn't have to remove the radiator.
Old 22-11-09, 10:48 PM   #7
beabert
Where do you live? someone might be able to help you if they are close by, update youe location in your profile
Old 22-11-09, 10:48 PM   #8
jnr-biker
no noise when it cuts out jus sounds like it being starved. cool will check this first thing in the morn cheers bud.
Old 22-11-09, 10:50 PM   #9
jnr-biker
im livin in athlone co. roscommon ireland
sudden loss of power Ben Flanagan SV Talk, Tuning & Tweaking 11 22-04-08 12:59 PM
Power loss!! chris8886 Bikes - Talk & Issues 12 01-12-07 12:56 PM
Unusual loss of power JimmyGulp Bikes - Talk & Issues 6 23-01-07 05:50 PM
Power loss? FreshAL SV Talk, Tuning & Tweaking 6 02-03-06 11:18 AM
Loss of power..... Nekkid SV Talk, Tuning & Tweaking 16 21-10-04 05:00 PM
