#21 | |||||
![]() ![]() Cheers Mark.
#22 | |
![]() ![]() have to say though i was very impressed with the brembo callipers on my rsv front end, who ever had them before didn't clean them at all and they have no corrosion at all. but on the rear calliper i think a good service every now and then would do Last edited by barwel1992; 21-06-10 at 03:53 PM. |
#23 | |
What is different about seals. Those use normal square section main seal and double lip seal dust seal. Are pistons alloy and coated or steel and chromed? How often you change pads? Mine were still OE after 40k. Why you care about anti squeal shims in caliper which does not squeal if serviced?
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 21-06-10 at 06:10 PM. |
Alternative rear shock for a curvy? | stew | SV Talk, Tuning & Tweaking | 15 | 10-04-10 09:10 PM |
Alternative Sv rear brake reservoir | maviczap | SV Talk, Tuning & Tweaking | 8 | 04-01-10 12:41 PM |
Rear Caliper... | Grinch | Stuff Wanted | 5 | 02-07-08 10:06 PM |
Cleaning all around the rear wheel / swingarm / rear brake caliper | Camel | SV Talk, Tuning & Tweaking | 12 | 28-04-08 02:00 PM |
replacement rear brake pedal alternative | husky03 | SV Talk, Tuning & Tweaking | 0 | 22-05-07 09:43 PM |
