Old 01-06-10, 04:04 PM   #21
Default Re: bit of a wobble.
Originally Posted by Miss_Undaztood View Post
I`ve always wondered why bike discs are made in 2 bits with those button rivet things holding them together ?
well one of bikes has fully rebuildable ones(apparently) so you can replace the outer rather than the whole lot...meant to be cheaper.
Old 01-06-10, 04:07 PM   #22
AndyBrad
it was a very slow slide, nothing spectacular really.
Old 01-06-10, 04:09 PM   #23
To allow for expansion due to heat without warping. Some clearance (rattle!) is fine.
Old 01-06-10, 04:21 PM   #24
Miss_Undaztood
Cheaper is always good
Old 01-06-10, 04:21 PM   #25
Miss_Undaztood
Ah ! That makes sense, thanks
"Every days a school day"
Old 01-06-10, 04:23 PM   #26
IME it is the inner (carrier) which gets the profiles of the bobbins battered into it allowing front>back play rather than the friction material getting worn away.
Do they do both the discs and carriers separate?
Old 01-06-10, 05:34 PM   #27
Dunno Chris, absolutely no idea. Not that I'll need them replacing any time soon, I hope.
Old 02-06-10, 12:57 PM   #28
AndyBrad
WELL
ive just got back from bike shop number 1 and the alignment is spot on and the computerised thingy confirms that everything else is 100% sooooo will try bike shop number 2 tomorrow and see what happens with the balancing etc. after that im at a loss.
Old 02-06-10, 01:05 PM   #29
Bri w
Bri w's Avatar
Sometimes you've just got to change the bike, or it will always nag at the back of your mind.
Old 02-06-10, 01:15 PM   #30
AndyBrad
It wont if its fixed
Front end wobble ranathari SV Talk, Tuning & Tweaking 9 17-02-10 07:47 PM
Wobble and instability trev SV Talk, Tuning & Tweaking 11 01-08-09 09:08 PM
Had my 1st wobble last night Nobbylad Bikes - Talk & Issues 11 02-10-08 03:39 PM
Front end wobble? rob13 SV Talk, Tuning & Tweaking 21 05-05-08 09:02 PM
Front end wobble SV andy SV Talk, Tuning & Tweaking 8 26-06-07 07:58 PM
