Old 21-06-10, 06:36 AM   #21
Razor
Default Re: SV wet front plug syndrome
the pyramid fenda extenda on their website is £16.99
Old 21-06-10, 08:30 AM   #22
Originally Posted by 2hys View Post
think how much it cost/ inconvenienced you the last time your bike brokedown, recovering the bike/pushing it, taking the bus/car, trying to sort out the problem...etc, etc then 20 squid don't seem that bad.. imo
I am fairly sure someone has actually been killed when the cylinder suddenly cut back in and spat them off.
No brainer. Fit something FFS!
Old 21-06-10, 04:03 PM   #23
sKiTz-0
£20 is bargain.
The ones I'd seen were more like £50 I'm sure!!!
sKiTz-0 is offline   Reply With Quote
Old 21-06-10, 08:22 PM   #24
Razor
CLICK HERE
Old 11-08-10, 11:29 AM   #25
Sly
I've had a recurring case of wet front plug syndrome and it seems to get to the rear pot too sometimes . I've ordered a fenda extenda and bought a pot of the grease recommended by my local bike shop, but it's not silicone based, as recommended by an earlier poster in this thread. It is Silkolene Pro RG2 which I've found out to be lithium-complex-based.
Is it suitable for use as 'dielectric grease' or not? Would I be better off using vaseline or buying something else?
I don't want to smother my HT caps in RG2 if it will be counter-productive and I can't find any info on its dielectric properties.
Old 11-08-10, 11:36 AM   #26
vasalene the cap and a small can of wd40 under the seat.
Old 11-08-10, 11:43 AM   #27
Sly
Thanks for the quick reply, Bibio.
I had to call out the recovery service (insurance policy perk) yesterday. The guy was great: It took him an hour of WD40, plugs out and in several times and finally a battery booster to get me going again, but he persevered rather than just taking me to the bike shop. I've got the day off today so really want to get all the preventative measures I can in place today.
Old 11-08-10, 11:48 AM   #28
Razor
squirt some wd40 up the drain hole on the front cylinder... make sure the drain hole is clear
Old 11-08-10, 11:49 AM   #29
you might want to check the drain holes in the bottom of the barrels to make sure they are clear and not clogged with muck. old metal coat hanger straighten out works.
Old 11-08-10, 11:54 AM   #30
Sly
I did them with pipe cleaners as I'd previously seen recommended somewhere. They were clear, but there was an accumulation of water around the front plug even so. I'll try shooting some WD40 up them as well.
Front spark plug problem or more serious? olisak SV Talk, Tuning & Tweaking 3 25-04-10 11:24 AM
Look after your front spark plug. Flameboy SV Talk, Tuning & Tweaking 11 16-01-10 12:23 PM
water in front plug 01 sv650s SV Talk, Tuning & Tweaking 32 03-11-08 08:42 PM
Front Spark Plug Biker_Billy SV Talk, Tuning & Tweaking 46 25-06-07 11:36 PM
Wet Front Plug fizzwheel SV Talk, Tuning & Tweaking 10 13-01-06 04:53 AM
