Old 28-11-06, 06:34 PM   #1
01 sv650s
Default water in front plug
i was going along the motorway today in the rain and my curvy started to misfire. when i got to collage i found out that it had water in the front plug cap. is there anything i can do to stop this from happening again
Old 28-11-06, 06:37 PM   #2
hovis
dont go out in the rain
have you got a fender extender? as this will help
Old 28-11-06, 06:48 PM   #3
Biker Biggles
Biker Biggles's Avatar
Fenda extender,silicone sealant over the plug hole cover,and make sure the drain hole from the plug hole is clear.
Old 28-11-06, 07:03 PM   #4
hovis
drain hole ?
Old 28-11-06, 07:34 PM   #5
ive never had this problem? i wonder why
Old 28-11-06, 07:35 PM   #6
Silicon goop from Maplins... Part number RE90X, costs £3.73 for the 50g tube and it'll do you for the life of the bike. It's basically a 100% cure. Slight pain to do the first time, thereafter you just do it whenever you change plugs- all it takes is a generous smear around the cap. Honestly the best £3.73 you'll ever spend on an all-weather bike, IMO.
Old 28-11-06, 07:38 PM   #7
Biker Biggles
Both cylinders have a drain hole.On the front it exits on the off side of the cylinder head just below where the tip of the plug would be when screwed in position.Poke it with a bit of thin wire and spray some WD40 up it.
Old 30-03-07, 06:50 PM   #8
dyzio
dyzio's Avatar
Default Re: water in front plug
Hello
Same problem here
I already have the fenda, I'll buy the silicone tomorrow.
Is there anything else that can/should be done to solve this?
Old 30-03-07, 07:00 PM   #9
BILLY
Originally Posted by dyziowg View Post
Hello
Same problem here
Not really either of the two will do the job! Me personally would go with the silicone greace I don't like fender extenders I had one come off and shatter my front mudguard fortunetly it didn't lock the front wheel up! And they look crap!
Welcome to the forum
Old 30-03-07, 07:04 PM   #10
chazzyb
I havn't had a problem since I fitted a fenda-extender. And it stops crap flying up over the front pot. Oh, is that why it works then?
Silicone grease on the front plug cap. ejohnh SV Talk, Tuning & Tweaking 10 21-02-08 06:44 PM
Front Spark Plug Biker_Billy SV Talk, Tuning & Tweaking 46 25-06-07 11:36 PM
Water logged spark plug Muzzy SV Talk, Tuning & Tweaking 3 08-03-07 06:35 PM
Rain in front plug - Will it clear itself? Stu SV Talk, Tuning & Tweaking 20 21-10-06 09:24 AM
Wet Front Plug fizzwheel SV Talk, Tuning & Tweaking 10 13-01-06 04:53 AM
