Old 20-02-08, 12:13 AM   #1
ejohnh
Default Silicone grease on the front plug cap.
I greased up the front plug cap last week and I noticed that there are 5 or 6 small holes in the cap which I presume are to normalise the air pressure under the cap. Wouldn't water get in that way anyway? So is the greasing of the cap doing anything to solve the SV front plug problem?
I'm looking at these two fenda extendas I have lying spare in my garage and contemplating having another go at fitting them to the bike before I take it abroad again.
Old 20-02-08, 01:41 AM   #2
Default Re: Silicone grease on the front plug cap.
Fairly pointless normalising air pressure since there's a drain hole that leads down the RHS of the front cylinder
Old 20-02-08, 04:26 AM   #3
Paul C
I live in a desert, so cannot act the expert at this, but di-electric silicone grease dabbed on thick enough will keep water out, and tends to stay in place.
On the other hand, if I lived in Jolly Olde, I would have a Fenda Extender fitted, no matter how it looked. And use the grease as well. Can't be too cautious.
Old 20-02-08, 08:16 AM   #4
Tiger 55
Yup. Going to solve it 100%, guaranteed, no extenda required! As for the holes...
Originally Posted by northwind
I block up all the breather and drain holes, they're only there to let moisture out so, stop it from getting in The only time there should be any need for vents other than that is if the plug allows blow-by, and a wee bit of silicon grease isn't going to be a problem in those circumstances. I can see the argument against doing it this way, mind, but I've had no ill effects these last 20000 miles
Prostrate yourself before the cap greasing master.
Old 20-02-08, 08:41 AM   #5
ejohnh
Thanks lol! I am well and truly prostrate.
As it happens, when I took the front plug out it was subject to quite a bit of corrosion.
Old 20-02-08, 07:34 PM   #6
Now the rear cylinder problem, that's a whole nother kettle of fish
Old 20-02-08, 07:35 PM   #7
Rear cylinder problem?
Old 20-02-08, 07:36 PM   #8
That one was for Tiger 55
Old 20-02-08, 07:43 PM   #9
dirtydog
Knob faced knobster
dirtydog's Avatar
Funnily enough i picked up a tube of silicone grease from maplins today so will be sticking that on there at some point
2001 SV650 in shimmerin green, Not broken anymore
Old 21-02-08, 08:11 AM   #10
Tiger 55
Aren't we all!
It was the coil, surprise surprise. And Mickey Oates didn't have one in stock so it's still there. Full rant to follow in Ecosse...
Front axle grease rob13 SV Talk, Tuning & Tweaking 1 03-09-07 06:43 AM
MCR City Centre - where to get silicone grease? El Saxo Pennine Massive 7 26-04-07 12:48 PM
Grease stuff to avoid water getting in front cylinder..... DanAbnormal SV Talk, Tuning & Tweaking 9 18-05-06 10:07 PM
Wet Front Plug fizzwheel SV Talk, Tuning & Tweaking 10 13-01-06 04:53 AM
Front & Rear calipers... where do I grease? Cloggsy SV Talk, Tuning & Tweaking 5 19-01-05 09:10 AM
