Old 21-06-11, 11:03 AM   #21
_Stretchie_
Large Member
_Stretchie_'s Avatar
Default Re: I'm such a tool, diesel BlackBird anyone?
Mr Stretchie,
You are no longer allowed to comment on my oil filling abilities without me bringing this incident up.
Regards, Mr Squirrel.
Do what makes you feel good, remember though, I have only done this once and as such retain the right to take the mick out of you....
How many engines you gone through because of your "oil filling in abilities"?
How to amuze an idiot:
Look right-> <-Look Left
Old 21-06-11, 11:22 AM   #22
Jamesy D
Friend of mine sold his absolutely mint-condition GSXR1000, built by Crescent to BSB standard with all the toys, about £30,000 worth of stuff on there. Had to sell it due to legal bills, ended up selling it to a van driver, who proceeded to ride it to the nearest garage, fill it with diesel, then not be able to ride it and break it for parts.
Not too good, but at least it was small enough that it didn't totally ruin the bike! Just waiting for when I do it now...
Old 21-06-11, 11:36 AM   #23
Luckypants
Luckypants's Avatar
Lesson here folks, don't fill up if you are tired, stressed or having an off day!
Yep, went to fill the car at 1am after a long drive Sunday night, half way through had a massive panic I was filling with petrol. Luckily it was just paranoia. I have put petrol in my car once in the past, but realised my mistake and brimmed it with diesel to compensate.
Old 21-06-11, 02:12 PM   #24
anna
anna's Avatar
Mr Stretchie,
He might not be able to, but there are plenty of others that will
Old 21-06-11, 03:11 PM   #25
DJFridge
I've not done it to the bike yet (fingers crossed, touching wood with my non-typing hand) but we have one diesel and one petrol car. Every time I go to fill one up, and I know Wifey does the same, I'm either chanting in my head "passenger : petrol" or "driver : diesel" to make sure I fill up on the right side. If the filler caps weren't on opposite sides on the two cars I think we'd have blown something up by now!
Old 21-06-11, 03:33 PM   #26
garynortheast
garynortheast's Avatar
My trouble is that I use the bike most of the time and automatically reach for the petrol nozzle when filling the tank.
Old 21-06-11, 05:23 PM   #27
suzukigt380paul
the one thing that most of you with common rail diesel motors dont realize is that if you put petrol in a diesel car and run any petrol through the pump say as little as a thimble/eggcup full then you can put a almost 100% chance that one day may be even 40k or more down the road on one cold british winters day a light will come on to say low pump pressure and a bill for about a grand,the pumps run at 100+bar and the only lube is the diesel and lack of lube is a killer,a mate in the rac says that most diesel pumps are good for 250k and almost all of the premature failer he has seen can be tracked back to petrol being added into the tank
Old 21-06-11, 05:52 PM   #28
Most petrol engines won't die horribly for quite a while if you get a bit of diesel in there. Mate of mine used to run contaminated petrol in his escort all the time, ran right enough if suitably diluted. If you start to hear pinking then add some more petrol or don't let it "lug" at low rpm.
Probably not a good idea long term but I would not be too fussed about 1l in a 15-20l tank. Ride it home, drain it out into cans and add a can per tank therafter to burn it off.
Old 22-06-11, 11:38 AM   #29
Stonesie
I have never mis-fueled, but the chap next door used to run his picasso HDI on scrapyard diesel that his brother got for him, 1 HP fuel pump and set of injectors later he started using pump diesel. those HP pumps are a bit more than 100 bar, old pug 306 D turbos inject at 175 bar and will run on just about anything, modern common rail diesels are scary high pressure (the current 1.6 hdi is 1600 bar) so the pump needs to have the lubrication or they die really quickly.
Old 24-06-11, 10:32 AM   #30
ian505050
Is it just me or should petrol and diesel have different shape nossels and holes so that its physically impossible to put the wrong fuel in? Like them shapes you try and push through holes as a kid.
Or am I missing something?.
Blackbird, Top Box, Castle Combe, Knee Down? squirrel_hunter Photos 14 08-06-10 03:04 PM
CBR1100 Blackbird forks Neeja Bikes - Talk & Issues 2 16-03-10 06:57 PM
Honda Blackbird Skip Bikes - Talk & Issues 45 17-04-09 08:40 AM
Honda Blackbird Alpinestarhero Bikes - Talk & Issues 67 30-12-08 12:58 PM
Blackbird Questions... DaBlackKnight SV Ecosse 17 23-04-07 11:18 PM
