#21 |
Any update on this?
I always thought that the bit of the bracket that goes under the swingarm should be U shaped to the thickness of the swingarm rather than L shaped this sort of design would stop the bend & damage the oem one does.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#22 | |
As far as I know this problem is only on pointies, not a problem at all on carby.
#23 |
that would help but would be a PITA when changing tyres as you would have to put the plate on first and while holding the plate push the spindle threw stop just before the spindle goes all the way threw to the other side and then put the other plate on then push the spindle home. the only way for it to be good enough is for the plate to go across the top and under the bottom that way you don't have to hold the plate in place while you push the spindle threw, but it would eventually mark the swingarm with rub marks over time which is bad news for black swingarms.
#24 |
Having this happen to me I now also have the dreaded circular scratch on my nice black swingarm. Anyone have a suggestion on the best way to cover it up? Which paint would work best?
Rear Axel Nut and Chain Adjuster Plate | toby_smith | Stuff Wanted | 3 | 26-09-10 11:20 AM |
chain Adjuster | thebluelion | Stuff Wanted | 12 | 16-07-10 08:11 PM |
Broken chain adjuster. | Ceebl | SV Talk, Tuning & Tweaking | 14 | 16-01-10 12:05 PM |
chain adjuster problem | steveg | SV Talk, Tuning & Tweaking | 6 | 11-09-06 06:01 PM |
Chain Adjuster Plate thingy... | andyaikido | SV Talk, Tuning & Tweaking | 17 | 12-05-06 06:51 PM |
