#21 |
True that was the only one I could think of except the Thundercat, which went the same way a lot earlier.
#22 | |
My local dealer has got the outgoing ER6 f for £5100 list
#23 | |
![]() Then I'd say there's been a structural failure on one of the parts in the engine, but that's just me and my opinion. Last edited by Steve_God; 06-01-12 at 08:26 AM. |
#24 |
In hyosungs defence, they're still bags of crap, but SV's blow up from time to time too.
#25 |
any engine will blow up given abuse, it just depends how long it took and how much abuse it took
#26 | |
Incorrect sized intake valves fitted causing engine seizing? wtf is that all about? - someone could have died because of that incorrect tooling issue from the factory. Big Fail.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 06-01-12 at 12:19 PM. |
#27 |
I know someone with the 125 version of this, its a pile of cra* its not that old and falling apart. I looked at the brakes as he said they didn't work to well, that was mess try sort that out. I wouldn't buy one, or suggest people should any type of this bike.
#28 |
Hmmm, a lot of digging at these Hyosungs...
I had a 2006 one for my 125 for a year up until early November this year. Good looking bike in my opinion, and has a few decent parts on it as mentioned USD forks which where actually quite decent, adjustable rear shock and a decent rear tire size. The breaks on mine were perfectly good enough for the bike. The engine had a decent amount of pull, with me at 11 1/4 stone and my friend at 12.5 it still managed 60mph (top speed i reached 79) I looked like a big bike and handled a bit like one too which was great to learn before moving up to a larger cc. For a 125 it sounded awesome with a Blue Flame exhaust but as mentioned the rest of the exhaust did age quite badly but not enough to cause problems, some of the paint on the frame had rusted but a quick sand showed it was barely eating the steel. Mine had sat outside for 4 months prior to me buying it and lived outside the entire time and has stood up quite well to the weather. They're surely heavier than need be but I didn't find that too much of a problem, and at 6,2 it fit me very well. Parts did take along time to deliver 1 month for a new chain adjuster. Overall mine wasn't a bad bike at all, I'd recommend the 125 model for a good bike to bridge the gap decent mpg and little problems. Although I'd definitely choose an SV over the Hyosung 650 any day! |
#29 |
So if I'm reading this right, you bought it at 4 months old and kept it for a year?
For paint on the frame to let rust through and the exhaust to corrode to any level is not a good performance on a bike that young. I sold my SV at 23,500 miles and 5 years old from new. It was used all year round and there was no corrosion on it. The only finish problem related to corrosion (not crashes) was flaking engine paint. |
#30 |
People say SV's rot, but it's not exactly true as it's only cosmetic surfaces on ally castings... not bits you want to retain the integrity of like the exhaust... and the frame and swingarm!
If you want a decent 125 buy a TZR...
Does anyone know what Hyosung 125s are like? | metalmonkey | Bikes - Talk & Issues | 6 | 05-04-11 03:26 PM |
2009 hyosung gt 650 r | rictus01 | Bikes - Talk & Issues | 19 | 06-02-10 02:26 PM |
Hyosung GT650R? | DarrenChay | Bikes - Talk & Issues | 30 | 17-07-09 04:12 PM |
whats your take on hyosung? | ZQ8Dude | Bikes - Talk & Issues | 51 | 02-10-06 09:41 AM |
hyosung spares?? | jim@55 | SV Ecosse | 6 | 18-03-06 12:09 PM |
