BSB & WSB Goto BSB Website
Goto WSB Website
Old 26-04-12, 11:47 AM   #21
muzikill
muzikill's Avatar
Default Re: BSB - how to follow british superbikes?
Dont expect to be a know all straight away just start following it as much as you can. check crash.net, the official bsb website and the mcn rag. When bsb is on you can listen to the trackday commentary using the online radio on the website (i have it on when i can over the weekend at home & when it is on eurosport at the same time) it gives good interviews & a insight into the teams/riders. It took me a couple of seasons to go beyond knowing the main teams/riders & helps with the amount of changes that happen in bsb.
Old 26-04-12, 01:54 PM   #22
sniff
sniff's Avatar
Originally Posted by pie_master View Post
He was a proper legend on the 125 - how's he getting on with the triumph? He seems to be doing well so far!
Rob is loving the T3. As he has said it fits like a glove. 4 races 3 wins and one 5th place. Oulton park next weekend should provide lots more info on the bike as so far we have only run at Brands, Thruxton and official test at Snetts. Going to be close between him, Phil Atkinson and James Egan for the title.
sniff is offline   Reply With Quote
Where can you see british superbikes? Paul the 6th BSB & WSB 4 19-08-10 06:15 PM
British Superbikes & MOT Dilemna tommyboy Bikes - Talk & Issues 3 04-04-10 07:21 PM
British Superbikes - CROFT 11/12/13 Sep rob13 Pennine Massive 4 14-09-09 08:24 AM
British superbikes: Donnington Liam9188 The Madlanders 2 10-05-09 11:50 AM
British Superbikes 09 - who will be going? rob13 BSB & WSB 15 22-03-09 09:46 PM
