Old 26-06-12, 08:55 PM   #21
xXBADGERXx
Default Re: Haggis Nibblers
Sausages wrapped in Donner Meat and then battered and fried off
Old 26-06-12, 08:58 PM   #22
SIII
SIII's Avatar
Talking Re: Haggis Nibblers
Where can I buy this???? Im salivating at the thought of that! Served in a pitta or Nan?
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 26-06-12, 09:04 PM   #23
With Chips and guaranteed to cause heart problems
Old 26-06-12, 09:06 PM   #24
SoulKiss
SoulKiss's Avatar
Even better idea
Haggis, wrapped in Donner, battered and fried
Old 26-06-12, 09:07 PM   #25
xXBADGERXx
Screw it , wrap all the Things and Batter them
Old 26-06-12, 09:08 PM   #26
Your drink sir!
http://en.wikipedia.org/wiki/Fried_Coke
Old 26-06-12, 09:11 PM   #27
SoulKiss
SoulKiss's Avatar
Did that once at a LAN Party.
We started out all refined, Tempura
Prawn, Salmon, Mushrooms, Vegetables of all sorts.
Then we were left with a load of batter and a pan of hot oil.
So in went the Tunnocks Caramel Wafers, Bread, basically if it was edible it got done.
Surprise of the party - if you batter and deep-fry cheap supermarket sponge cakes, they are VERY like doughnuts
Old 26-06-12, 09:29 PM   #28
xXBADGERXx
Originally Posted by soulkiss View Post
surprise of the party - if you batter and deep-fry cheap supermarket sponge cakes, they are very like doughnuts
lmfao
Old 26-06-12, 09:37 PM   #29
muzikill
muzikill's Avatar
Yum....
Old 26-06-12, 10:27 PM   #30
-Ralph-
I don't like the microwave, it sometimes dries the haggis out, and I don't like boiling it, as I buy haggis in a proper sheeps stomach and it has a tendency to go soft and split in the boiling water, ruining the haggis.
These days I use a steamer. Even if it splits open it just spills out into the steamer tray and stays nice, moist and tasty.
It doesn't really matter how you warm it through, you want to get it piping hot right through to the middle, but the Haggis is already cooked when you buy it.
It's all going well... and then you're off! (Haggis down) haggis SV Ecosse 34 20-05-09 01:34 PM
Haggis missyburd Idle Banter 48 28-01-09 07:45 PM
SVR stickers - Thanks haggis svrash Photos 11 18-07-06 04:37 PM
Has Haggis Surfaced Yet? Quedos Idle Banter 2 21-06-06 12:33 PM
