#21 | |
*for those youngsters that cannot get their head around this just imagine being legally allowed to go out on your low mileage, one owner, L-plated Honda H100 on your 17th birthday without a single lesson and with nobody supervising you (as long as your provisional licence had turned up in the post). And if I'd been a bit older I could have gone out likewise on a 250!
We are the Goon Squad and we're coming to town, BEEP BEEP! |
#22 |
I failed twice, the first time was a really unlucky and weird situation which he said he didn't like to fail me on (but still did) and the second time I was probably a bit over-confident and rode like a normal ride, failing for going through an amber light and rushing over a zebra crossing.
Anyway I changed site for the third try and passed without any faults, it was in an area I knew better which helped and the instructor was a decent, normal guy who warned before the test about doing *too many* lifesavers. So I guess it does have a bit to do with your examiner, but either way you do benefit from having your riding critiqued by someone much more experienced than yourself. |
#23 | |
#24 |
#25 | |
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#26 | |
I believe all the advice here will be useful to you. But you'll have to find your own way. What I can guarantee is that the moment you pass is the same moment when everything will just "click" and after that you'll be asking yourself what all the fuss is about. Don't worry about the money. If you're determined then just focus on acheiving something which is not easy but will give you great satisfaction when you succeed. And on that note, I wish you the best of luck in the world. |
#27 |
#28 |
The £600 is referring to the DAS training. I can't remember how much I spent. I think it was £60/session, of which I had 4. Then add on the CBT for about £120, theory tests (yes TESTS in my case), Mod1 and Mod2 tests. So Missyburd's £600 sounds about right.
Cheapest way is obviously to do your CBT, do 2 years then take your tests without tuition. All in that'll still probably cost about £300 these days.
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#29 | |
The test was just a lap round town, no manoeuvres or 'owt? I think I was put in for test so quickly as I turned up for the CBT on my old ZZR11. EDIT: I must point out I am not condoning such activities or saying it's a good idea! Last edited by Thunderace; 16-11-12 at 06:20 PM. |
#30 |
I had 2 weeks of in August this year and got my cbt theory and mod1 done in those 2 weeks then had to wait till October 26th to do mod 2.
Passed all of them 1st time thankfully no training but i did get 3 minors on the mod 2 my brother in law had his mod 2 15 mins before mine and passed with 2 minors. I have been driving for the last 18 years so i think that helped a lot. |
I feeling I am failing | Littlepeahead | Guildford Massive | 3 | 22-10-12 01:44 PM |
What do you do when you failing to Cope | 454697819 | Idle Banter | 27 | 30-03-10 08:31 AM |
Forewarning of failing reg/rec? | ranathari | SV Talk, Tuning & Tweaking | 11 | 07-01-10 01:31 PM |
Is my clutch failing? | ukrobuk | Bikes - Talk & Issues | 25 | 19-05-08 10:10 AM |
My memory is failing. | timwilky | Idle Banter | 3 | 02-12-06 06:56 PM |
