Old 29-01-13, 12:36 PM   #21
madnlooney
Default Re: K3 not changing between gears 2 and 3
managed to press the gear lever from the the footpeg. it was gunked up well so greesed and now changing a gear perfectly. Thanks to all for the replys and suggestions
Old 29-01-13, 01:47 PM   #22
Blueperson
great stuff
Old 30-01-13, 08:05 AM   #23
muzikill
muzikill's Avatar
Nice one. & thank fook!
Problems changing gears. bmack999 SV Talk, Tuning & Tweaking 3 24-06-11 09:31 PM
Changing down gears is like standing on a sponge... JimmyGulp Bikes - Talk & Issues 5 19-02-07 11:19 AM
Problems with changing down multiple gears Grinch SV Talk, Tuning & Tweaking 26 16-01-07 12:18 PM
Problem Changing Down Gears leegriffiths128 SV Talk, Tuning & Tweaking 5 03-04-05 11:32 AM
