#21 |
I have the same problem as the OP, my plan is to reassemble the front brakes and bleed the brakes to gain enough pressure to force the pistons out.
Can someone explain the bleeding process for an sv650? |
#22 | |
Bleed from the top to get all the air out, so squeeze air out of the junction hose and bleed master cylinder banjo before starting on the bleed nipple. The system needs some fluid in it before you can get pressure at the lever. If the lines already have fluid then bleeding should be easier. Assuming you have no leaks in the system; get a spanner over the bleed nipple; cover the niple with a peice of hose connected to a bottle or container with fluid in it (so no air can come back up the system); pump the lever and hold; open nipple whilst squeezing lever to the bar; close nipple quickly; pump lever and repeat until you get a firm lever. Keep topping up the reservoir. The pistons should be out after a few good pumps with some pressure at the lever. There are more detailed instructions on the site if you use the search function. Also loads of stuff online. Its the same process for most hydraulic bikes really. Last edited by Runako; 31-01-13 at 08:05 PM. |
#23 |
Basically, I drained all the fluid and took my calipers off to inspect everything, I later found out that the pistons were seized (all 4) so my plan is to reattach it all and then force them out.
"Squeeze air out of the junction hose and bleed master cylinder banjo" - Can you explain how to do that please? I'm really inexperienced with bikes... All help is most appreciated, I'm working a late shift tomorrow so I'd like to get this done tomorrow morning if possible. ![]() |
#24 | |
#25 |
You've got the brake system apart now, so don't fuss about putting it fully back together, just connect one line from the master to a caliper, push the pistons out, then do the other caliper after.
Bleeding: Fill reservoir, open bleed a bit, pull lever and hold, close bleed, wait a few seconds and repeat. Important bits: 1. Do wait a few seconds after closing the bleed before releasing the lever - particularly when the system is completely empty. 2. Don't release lever even a little bit when bleed is open - only when it's closed. 3. Don't let the reservoir empty out - you'll have to start all over again. 4. Don't waste money on silly 'easy bleeding' gizmos.
#26 | |
#27 |
Well, that's actually a pretty god solution. Glad you got it sorted
#28 |
I'd like to point out I borrowed the one I used.
![]() Also I looked all over for a bleed nipple for my MC but realised I don't have one. Apparently the process in this case is to: 1. Fill reservoir 2. Squeeze brake lever 3. Crack banjo at the MC for a split second (long enough to lose a bit of fluid) 4. Retighten 5. Repeat Also I read some ridiculous thread which says: 1. Remove brake line at the MC 2. Cover MC brake line hole with your finger 3. Fill reservoir 4. Slowly pump lever which will push out air and fluid past your finger 5. When only fluid is coming out, whip your finger off and quickly thread in brake lines before all your fluid ****es out on the bike ![]() Both these techniques seem like a good way to cover your bike with brake fluid. Is there a better way? (Besides the mighty Mityvac) ![]()
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#29 |
Yes, bleeding it properly. Which means that you don't need to bleed the master cylinder, this also explains why the overwhelming majority of brake master cylinders don't have a bleed nipple, (like yours), it's simply not needed.
#30 | |
You don't have to bleed the banjo until its pouring fluid. Just enough so that its not fizzing air. When the fluid starts to come through stop. All i needed was some rag or doubled up paper towel under the banjo, that should be enough. Close the banjo and then bleed normally. This worked for me. From this point, including bleeding both calipers, it took 5-10 minutes. |
SV650K3 Brake Pistons - where do you get yours? | Longway | Bikes - Talk & Issues | 2 | 17-01-12 06:55 AM |
Best way to clean up brake pistons? | curium | SV Talk, Tuning & Tweaking | 12 | 06-04-09 09:42 PM |
Brake Pistons? | vardypeeps | SV Talk, Tuning & Tweaking | 4 | 29-08-08 12:12 PM |
scaring on brake pistons | huge | SV Talk, Tuning & Tweaking | 2 | 13-01-06 04:32 PM |
new brake pistons and seals. where from? | raymond smith | SV Talk, Tuning & Tweaking | 2 | 30-04-05 09:24 PM |
