Old 14-09-13, 05:35 AM   #21
chezvegas85
Default Re: She's dead Jim.
Originally Posted by rp16v View Post
try a compression test while turning it over by hand/crank may be rings if its small shards of metal in oil,could explain the oil being burnt off getting past the rings, was is smokey on start up or while running?
used to be during winter (start up), hasnt been during summer
Old 14-09-13, 05:36 AM   #22
chezvegas85
Originally Posted by jambo View Post
Well if there's debris in the oil then your bike's really after another motor. Sorry to hear that!
Jambo
by the looks i dont think its financially viable, i reckon shes only worth about 6-800 anyways. so will be sold as parts i think and buying a new baby
Old 14-09-13, 08:10 AM   #23
Matt-EUC
Default She's dead Jim.
Break and sell the parts. You'll get more than she's worth as a whole bike.
Old 05-10-13, 12:09 PM   #24
apchara
i done an oil change yesterday filled to full line, rode about 80 miles and it didnt cut out just lost power and only revved to 5k, same solution you reckon???
oil is a bit under full now
Old 05-10-13, 03:59 PM   #25
full as in. full sight glass when bike on side stand or bike upright?
Old 05-10-13, 04:06 PM   #26
apchara
Bike upright and level
Old 05-10-13, 04:08 PM   #27
had you run the oil level low before the oil change?
Old 05-10-13, 04:21 PM   #28
apchara
No was always at least 5mm above E with bike level and cold ive been riding thr bike since Wednesday, had stripped and cleaned carbs, partially drained tank, new sparks, hi flo filters for oil and air from WEMOTO. COM and ngk sparks bike ran super sweet after oil change too it about 70-80 miles after oil change, triple figured for 3 miles then back out to the sticks from city, went down a hill, span a u turn back up the hill (trying to find my buddies)
Back down the hill it lost power, the spark cap was smothered in cv grease to help with the wet plug issue, bike has a fender extender to stop that happening, both of the black things in the carb mover freely and feel the same when moved by hand, I blew up thr overflows ans there is a good supply of fresh clean fuel flowing through the needles, which evaporated off the butterflies as the engine was warm, cran breathers are on the airbox tight and the oil catch filter has been rinsed with petrol to help clean, there are no peculiar noises from the engine apart from the odd pop at idle which sid squid diagnosed as the "idle port?"
Old 05-10-13, 04:27 PM   #29
when you say plug cap smothered in CV grease do you mean up the cap or round the flange that seals the chamber at the head?
you don't need to smother it you only need a light coating and enough to seal the outside elements from getting inside.
if bike was running fine before service then its something you have done while servicing.
Old 05-10-13, 04:39 PM   #30
apchara
The top flange where seals by top of rocker cover
Bike ran fine wednesday night thursday day time, after the basic sparks and filters with carb clean, the only thing done friday was the oil change, dropped sump plug and the oil feed plug/bolts that seem to go straight up each cylinder, then removed filter left to drain for an hour wobbled biked around then wood block under the kick stand to hold upright, then bit of the old gt85 round the bolt bolt holes and edge of filter mount to wipe down gunk, then all plugs/bolts back in place oiled rim of filter re installed as tight as possible by hand added 2 litres of oil, checked level and added more until the bottom of the (maniscus) oil level was on F
On that basis I dont think it was something done in the service to cause the problem, as it ran finr for 2 days and after thr oil change, the bike had been sitting for 10 months prior to service, has had a new battery and the previously mentions bits changed
Other threads of a similar issue have not resolution to the issue, one part of the foam is loose under the tank but on thr left side half way down and nowhere near the airbox inlet
SV dead :o( Gemaroo Bikes - Talk & Issues 19 02-03-10 07:27 PM
Dead 02 SVS 2whelltraveler SV Talk, Tuning & Tweaking 4 12-05-09 01:25 AM
sv k3 dead!!!!! aitch Bikes - Talk & Issues 10 19-06-06 04:57 PM
Dead Can? M65 SV Talk, Tuning & Tweaking 19 09-05-06 12:12 PM
HELP - Dead SV Roy650s SV Talk, Tuning & Tweaking 17 01-03-06 08:37 PM
