Old 14-03-14, 10:39 AM   #21
chris8886
chris8886's Avatar
Default Re: 9 volt connector for satnav?
Originally Posted by PyroUK View Post
Here you go mate:
This is the main socket, it's got a rubber weather cap and the wires going in are sealed. It also has a mount built in with 2 holes for fitting:
It's got spade connectors on a short pair of wires:
And 2 individual lengths of wire for the positive and negative feed.
The positive has an in line fuse near the battery end which has a circular connector:
Unfortunately a well meaning but slightly ham fisted house mate managed to pull the circular connector off the negative wire when cleaning up:
Originally Posted by Specialone View Post
Yep, the official 12v plug chargers that come with the satnavs have step down transformers built in to the plug, never cut one off and try to hard wire in without checking the voltage the satnav receives.
thanks guys for all the info!
AR08 to AR13-QUALITY!
Where to buy this connector? djotanov SV Talk, Tuning & Tweaking 6 22-11-11 09:02 PM
Volt regulator? sandman Thames Valley 19 02-05-10 05:02 PM
Advice installing 12 volt outlets pale rider SV Talk, Tuning & Tweaking 5 31-07-09 06:49 AM
SV sidelight connector DarrenSV650S SV Talk, Tuning & Tweaking 2 04-07-07 10:47 PM
Volt Meter Fitting pablohoney SV Talk, Tuning & Tweaking 3 27-06-06 02:11 PM
