#21 |
Gonna tackle the sv today ?!!
#22 |
I have noticed there was a ****ty scotoiler once connected found the remain of a vacumm tube but cant see where it was connect on the intake?
Also is there a automatic choke or does the injector just change the amount of fuel input via a sensor. |
#23 |
Sorted i think new plugs and cleaned collections fresh charge and new fuel. ....probably an injector air fuel issue
#24 | |
If there was an issue with the fuel injection, what corrected it? Or did it heal up on it's own? I like heals up on its own repairs. |
#25 |
No actual choke as such, FI system has ECT and IAT sensors which allow map to alter injector duration, and secondary throttle valve actuator has a cam on its spindle that cracks the primary to lift tickover.
#26 |
Speaking out of Naivety here but could this have been anything to do with TPS/Idle problems? combined with cold temperatures maybe these just weren't sitting where they should have been?
When I recently did my TPS adjustment I moved the sensor too much one way and got my idle all out of wack as well. Had real struggles starting it until I got all this straightened out. A fresh day and a charged battery got it sorted no problems. |
Fake fire place surround and fire. FREE | Ch00 | Idle Banter | 6 | 09-09-14 03:26 PM |
OMO: Gas Fire | -Ralph- | Idle Banter | 11 | 02-12-12 06:20 PM |
Fire in the sky. | rictus01 | Photos | 10 | 12-10-09 11:09 AM |
Fire & Ice | Kinvig | Idle Banter | 4 | 09-11-07 03:37 PM |
