Old 12-04-16, 02:05 AM   #21
Red ones
Red ones's Avatar
Default Re: Slow Rev Limiter Bounce on K6
From SVRider:
C42 is ignition input to ecu not present. Check the 4 pin green connector below tank open and spray in contact cleane then remake. If you have a volt meter you should have around 6vdc from the orange/ red wire to ground when the ignition is on. If not likely the ignition switch at fault.
Old 12-04-16, 08:15 PM   #22
auronini
Junior Member
auronini's Avatar
Cheers i'll have a look at that, got exams in a couple weeks now so i'll have a look when they're done and see if it fixes anything
auronini is offline   Reply With Quote
Old 14-04-16, 01:11 PM   #23
K5Rider
Originally Posted by Craig380 View Post
The other point is that the SV revcounter is optimistic - over-reading by over 10% at higher rpm, so that when the needle is showing 11,000, actual RPM is under 10,000. See this thread from SVRider: http://www.svrider.com/forum/showthread.php?t=138676
Mine seems to hit 11900rpm on the 2 or 3 times I've hit the limiter, then bounce between that and about 11500rpm.
Botched changes and me not changing up when having a blast are to blame !!
Crash.NET - Second top six on the bounce positive for Petrucci NewsBot News 0 13-09-15 06:30 PM
sv cuts out and revs bounce LondonSv SV Talk, Tuning & Tweaking 2 13-07-15 01:02 PM
Crash.NET - Late bounce for soft-shod Dovizioso NewsBot News 0 02-05-14 07:00 PM
BBC Sport: Fearless Marquez bids to bounce back in Barca NewsBot News 0 13-06-13 06:20 AM
Can I bounce your bike? Mark_h Guildford Massive 8 22-06-06 10:43 AM
