Old 20-05-25, 05:48 PM   #21
glang
Default Re: K3 front end
This is an S right? The clip ons go below the top clamp and the fork tube is set so its top is exactly level with the top clamp. All shown in the excellent Suzuki workshop manual free to download online....
Old 21-05-25, 09:33 AM   #22
Fazer Fail
Junior Member
Hi yes 2003 S model was converted to bars and aftermarket top yoke but in this time forks were off to get seals done or so history says.
Yes clip on are below the yoke and seated in the retaining lug, when the oem yoke was refitted the top of the forks are uneven one side 4.5 mm below the surface, other 3.6 mm below the surface.
I assume the flush means the top of the tops flush with the thickness of the top cap showing or bang on flush with the top cap?
The poor old thing had a saggy rear shock and it seems raised front end must have felt very different.
Fazer Fail is offline   Reply With Quote
Old 21-05-25, 12:56 PM   #23
garynortheast
garynortheast's Avatar
On my curvy the stanchion is flush with the top of the yoke, and the cap sits proud of the yoke with just the thickness showing, as you suggest.
Blue Curvy S with over 110,000 miles and still going strong.
Wanted Sv 650 curvy front right hand side front fairing blue swifty09 Stuff Wanted 7 28-12-11 08:00 PM
Injected Front Wheel Axle and Front Master Cyl Brkt adjblade Stuff Wanted 2 19-01-11 08:07 AM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
