View Poll Results: Have you fitted a rad cover to your SV ?
yes to my naked SV 7 14.29%
yes to my SVS 9 18.37%
no 33 67.35%
Voters: 49. You may not vote on this poll
Old 15-08-04, 08:00 PM   #21
SVTONYB
Interesting..... I've seen them advertised but always thought they were for naked bikes....
Old 17-08-04, 03:26 PM   #22
karen
Just put one on,it was a cover for a naked sv,but i made it fit.Cut out a piece to fit round the top plastic's,drilled a hole on each side of cover and put some liquid metal on side of radiator.Put a nut into liquid metal let it dry and then put small bolt through cover,so that holds it on.Also put some liquid metal round bottom of the cover,just to make sure. Also Put some tie wraps through the cover and round the top part of the radiator ,the two bolts that hold it on to the frame just in case
Old 17-08-04, 03:52 PM   #23
curium
Default Re: Does your SV have a Rad Cover
Originally Posted by SVTONYB
I have just had my radiator burst with a stonechip or similar....
You must be unlucky as my rad is actually bent from 2 offs and still doesn't leak.
Old 17-08-04, 07:36 PM   #24
Stig
Mine too
K4 rad cover fit K5? cb5_keith SV Talk, Tuning & Tweaking 5 18-03-09 05:15 PM
rad cover curvey scottjames SV Talk, Tuning & Tweaking 3 13-10-08 10:08 PM
Scorpion rad cover heros SV Talk, Tuning & Tweaking 4 01-07-08 11:11 AM
Clutch Cover carsounds_dan SV Talk, Tuning & Tweaking 17 12-06-08 04:27 PM
Cover pic Ed Idle Banter 15 01-03-06 02:22 PM
