Old 11-06-08, 03:59 PM   #1
carsounds_dan
Default Clutch Cover
Hi,
Anyone know of any aftermarket clutch covers available for the curvy sv? and roughly how much they go for?
I've contacted a fellow on a german site about one with a window in it but he said that he isnt going to make any until there are 10 buyers ready.
If anyone wants one let me know and i'll start making a list, other than that what other options are there? is there any off of other bikes that fit?
cheers
dan
Old 11-06-08, 04:13 PM   #2
zadar
Default Re: Clutch Cover
there is bunch of them available in USA.round clutch cover only,not whole side.
Old 11-06-08, 04:27 PM   #3
carsounds_dan
meaning? do you just mean that the cover is available but just the clutch one, not the side engine casing aswell?
Old 11-06-08, 04:32 PM   #4
Dangerous Dave
Yes just the clutch, early Curvy's have separate clutch covers. They are made from Aluminium and two at least come with a crash bung, one plastic and one steel.
These three are available from JHS, problem is there are reports of condensation building up behind them and contaminating the oil in our lovely British climate!
Old 11-06-08, 04:35 PM   #5
zadar
right.clutch cover is just round piece.engine cover is whole side.
I think there is guy on svrider that installs window it them,not sure tho.
Old 11-06-08, 04:38 PM   #6
zadar
never had problem with condensation.
some covers like factory pro have casing for bolts inside that gets in the way if you use slipper clutch.
Old 11-06-08, 04:43 PM   #7
carsounds_dan
I doubt i'll ever go for a slipper.. I blip.
I asked JHS about the woodcraft one and they said it was like £170+VAT which is a bit steep, I recon i might just get their cheap billet one.
What else is available? are there no other suzuki model covers that fit?
cheers
dan
Old 11-06-08, 04:49 PM   #8
Dangerous Dave
Nope.
I had the condensation effect the 750, never had a problem with the OEM plastic one fitted. Several others have had the same problem, 650's and 700's. Problem reoccurred when I refitted the Factory Pro one again after crash damage ruined the OEM one.
Old 11-06-08, 04:57 PM   #9
carsounds_dan
hmmm... the woodcraft one looks nice... how much clearance does the standard cover leave?
cheers
dan
Old 11-06-08, 05:02 PM   #10
Dangerous Dave
Are you on about ground clearance, if so you will not have a problem with any touching the deck (unless you crash).
bloody clutch cover AndyBrad SV Talk, Tuning & Tweaking 42 03-03-09 08:22 PM
Leaking Clutch Cover TheShadow SV Talk, Tuning & Tweaking 2 16-02-09 04:30 PM
Clutch cover 01 Curvy jumjum_0214 Stuff Wanted 9 10-10-08 05:08 PM
Clutch cover. scottjames SV Talk, Tuning & Tweaking 8 16-04-08 11:30 AM
clutch cover leaking habbie SV Talk, Tuning & Tweaking 0 06-05-07 02:07 PM
