Old 24-02-05, 08:22 PM   #21
Jabba
I'm of the jonboy school of riding - slow (but not as slow as him ) in, quick out. To that end when out on the open road I hardly use the rear brake at all and try to get all my slowing done before the bend.
Having said that, the rear brake on my 'ornet isn't that powerful and I'm going to have the brake fluid changed at the forthcoming service. I can't even lock the rear wheel with it at the moment Perhaps that is a good thing?
I use the rear for slow-speed manouvring, when on loose surfaces or when filtering. Obviously, I use it in an emergency to dump speed.
Interesting discussion
Old 24-02-05, 08:22 PM   #22
Originally Posted by jonboy
Oh I see, well yes when it comes to it I use the front brake to maximum effect in order to stop sharply when the occasion arises no problem. What I'm saying is that I use the rear brake 80% of the time as I tend to brake early and prefer the old racing adage of "slow in, fast out" with regard to corners..
Gotcha. Sorry, I'd misunderstood- your way's actually possibly the most sensible, since it gives you a safety margin that most people don't give themselves...
Old 24-02-05, 08:25 PM   #23
RandyO
front brake should be your primary braking power.... as you apply brakes you weight shifts forward towards the front, to a point that the rear actually becomes useless.... the tire has to be on the pavement for the wheel to have any braking action.
you can use front brake effectivly in wet or gravel, you just have to be smooth about it..... but front brake is primary braking regardless of surface
Old 24-02-05, 08:40 PM   #24
jonboy
Originally Posted by northwind
At this point, some yank will always say "If you're using the front brake to its full extent the rear will be in the air"
and then...
Old 24-02-05, 08:50 PM   #25
That's a bit unfair
Old 24-02-05, 08:51 PM   #26
Spiderman
Where the hell am I?
Spiderman's Avatar
From years of riding bikes with no engines (racers & mountains) i'm just so used to the feel of the braking thru my fingers.
The rear brake to me has always been a stabiliser and additional stopper when needed mainly cos its under-foot and i'm used to the hands braking... its just a natural reaction kinda thing.
I'm about 80% front 20% back
Tho when filtering at slow speed its maily back for delicate throttle work.
I think everyone should learn the art of using only the front.... and then only the back, then find their own combo.
Isnt the front tyre desinged to flatten more just for this reason? All the weight over the front whilst braking in a straight line so it gives a slighlty wider surface area for contact and grip?
I find i lock the rear too easy too
Old 24-02-05, 09:08 PM   #27
Viney
If the back wheel aint off the ground, you aint using the front brake enough!
Old 24-02-05, 09:55 PM   #28
Iansv
I'm sure Tim would agree with that... (Sorry Coombest)
Old 24-02-05, 09:56 PM   #29
Anonymous
use front brake if i have to scrub off a lot of speed with a touch of back brake to stabilise the bike. dont really use the brakes much at all though still got original rear brake pads on and the bike has done 25000 miles. dont use front brake unless completely upright in a straight line though
Old 24-02-05, 09:58 PM   #30
Biker Biggles
Biker Biggles's Avatar
I allways apply some front brake and normally use about 80 20 front rear bias.I think the Yanks are basically right in that if you are getting maximum benefit from the front the weight transfer will render the rear allmost useless.Even in poor grip there is still a noticable weight transfer,and thus a reduction in rear grip.You still get most of your stopping from the front.I once had to ride home when I lost the front brake completly and that taught me just how far it takes to stop with just the rear.I now know why supertankers crash.
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
