View Poll Results: Countersteer! Push or Pull ?
Pull 5 10.00%
Push 41 82.00%
What's counter steer ? 4 8.00%
Voters: 50. You may not vote on this poll
Old 11-05-05, 07:40 PM   #21
Carsick
K, thank you. Your explanation is the first time I've actually twigged how to point your shoulder into a corner properly.
Just had a bit of a romp before it got dark and I could feel it making a slight difference as the bike turned in.
Old 11-05-05, 07:46 PM   #22
Anonymous
No blloody idea. Probably push, but actually maybe a drop of the shoulder on the corner side dropping the bar down into the lean...
no, it doesnt bear rationalisation does it.....
Ive never thought of it as a pull
but maybe it is.
Tell you what tho Im not going to start thinking about it when riding as it will never work then
Old 11-05-05, 07:48 PM   #23
Anonymous
I didnt notice this at all on the SV but notice it all the time on the GS.
Old 11-05-05, 09:45 PM   #24
K
Ahh good, I'm glad it made sense to someone... as I'm not too sure it made sense to me!
Old 11-05-05, 09:58 PM   #25
Carsick
It made bugger all sense until I went out on the bike and did it.
I realise now that to some degree I already do it, but doing it consciously seems to make a difference.
Old 11-05-05, 10:20 PM   #26
TrojanHorse11
I'm sure you can all guess which one I voted for in the poll
Old 11-05-05, 10:44 PM   #27
Shooter
One hopes that the PUSHERS & PULLERS are talking about different sides of the bar when they consider what they do.
eg - you can not achieve the same result by Pushing / Pulling on the left hand bar for instance .
Old 12-05-05, 06:16 AM   #28
Peter Henry
A contentious little issue this is! At the end of the day,if what ever you do on a regular basis sees you negotiate curves smoothly,safely and without drama then stick with it. Only begin to analyse if you feel you want to improve your technique or be able to carve the turns quicker.
Old 12-05-05, 09:15 AM   #29
Balky001
Balky001's Avatar
I only ever pushed but I'm trying a bit of both now. Pushing is far smoother and natural to me, but pulling at the same time can get the bike on its side quicker for thos flip flop moments. I think if you are leaning heavily and hanging off the side you are naturally pushing on the inside bar without noticing as the bar is closer to your body (you might be pulling too!)
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 12-05-05, 09:44 AM   #30
Ceri JC
Usually use push (I find I can control it more finely).
Pulling is know as 'active countersteering' (rather than passive) and tends to be quicker/more severe. I find Pulling better for if a bend tightens up or you need to avoid something suddenly.
Were to get Throttle cables(push and pull set) curvy 2002 Nicky S SV Talk, Tuning & Tweaking 10 03-09-08 02:24 PM
Did I pull? melody Idle Banter 43 05-10-07 02:42 PM
rattling on pull off emcf Bikes - Talk & Issues 5 02-06-07 10:45 PM
Oops! Do they have to pull you over? howardr Bikes - Talk & Issues 12 19-11-04 03:29 PM
