Old 20-07-05, 09:03 PM   #21
brolong22
hey i didnt write the list peter, it must be cos you lot are so few and far between you have special bearings
Old 24-07-05, 07:08 PM   #22
Did you find the bearings you needed? 'cos if you're still looking I've just stumbled across the parts book that has the bearing dimensions in it.
Shall I look in the book?
Old 24-07-05, 09:12 PM   #23
brolong22
If you dont mind sid, im still waiting to hear off my mate to see if he can sort me the bearings out.
Old 24-07-05, 09:18 PM   #24
OK, according to the Bickers big book of bike bits 'n bobs:
Top bearing: OD 47mm, ID 25mm, Height 15mm
Bottom bearing: OD 55mm, ID 30mm, Height 17mm
Old 26-07-05, 12:04 PM   #25
brolong22
Cheers Sid, i didnt realise there were two different sized bearings. If i were quoting the number you gave me before when ordering does this refer to a set of the two bearings together?
Old 26-07-05, 12:33 PM   #26
Patch
Yes it should certainly does with the VFR ones when ordered from Moore. By the way they are only 30 quid ish delivered.
Old 26-07-05, 03:24 PM   #27
He's right you know.
Originally Posted by I
The reference for the set is SSH901.
Dead giveaway I thought.
Old 26-07-05, 04:29 PM   #28
brolong22
Old 26-07-05, 04:48 PM   #29
wheelnut
And you should find some decent bearing suppliers in Brum, for anyone oop north, try George Lodge in English Street in Hull.
slightly off topic but I rebuilt a forklift mast and saved over £6000 on original bearings :P
Headstock paddock stand wanted nicky-jano Stuff Wanted 1 13-05-09 11:04 AM
Headstock bearing/fork knock swinging_simian SV Talk, Tuning & Tweaking 6 21-08-08 08:44 AM
Headstock stand £40 tomjones2 For Sale - SV's and SV related items 3 29-11-07 05:09 PM
Paddock Stand - Headstock type GrahamC SV Talk, Tuning & Tweaking 14 28-10-07 09:03 PM
sv650s k6 headstock torque settings rosco SV Talk, Tuning & Tweaking 2 14-07-07 01:28 AM
