Old 25-08-05, 08:08 AM   #21
The Mass
Originally Posted by enzyme
Yup , mine fell out on the A10 slowing down to a roundabout which was not a fun experience , then spent 1 hour at the roadside waiting for the great free Suzuki road side assistence , before finally finding my tool kit ( never though of reading the manual when I got the bike ) and fixing it myself Now I check it every few weeks just to be sure...
Enzyme,
Can you please phone Suzuki with your details. The more people we can get to phone, then they might do something about it.
it's a free phone number: 0500 011959
Cheers - Mass
Old 28-08-05, 03:57 PM   #22
tigersaw
tigersaw's Avatar
I've not really understood what it is that comes loose from the descriptions in this thread, so I took a look at my K5 this afternoon.
Correct me if I'm wrong.
It appears the gear change lever sits on a shaft which is threaded into the same casting as the footpeg. If you remove the circlip the gear lever will slide off, and the shaft can be removed/tightened using a 17mm spanner on the straight edges at the far end. You need to remove the gear lever to expose it. I assume this is the rod which comes loose? Mine was very tight. I've also cut a notch in it at 'north' with a junior hacksaw so I will soon see if it ever works loose.
Looking at it, if it were to work loose so much it fell out, it would still be retained by the circlip and nothing would be lost.
Old 29-08-05, 04:27 PM   #23
The Mass
I'm not too sure if the K5 is the same setup as the K4.
Yes you are right about the circlip holding it in place. But the whole thing will fall off or out. including the circlip, so the whole shaft will move.
worth having a look as under closer examination of all the models K3 -> it loooks to me like they have been "playing" with this part of the bike for a while, as the K3 model has it built into the footrest where the K4 and possibly K5 have it as a seperate entity to the bike.
All the same Suzuki are just shoeing us off with any excuse, we shouldn't have to put up with bits falling off your brand new bike after or before its first service???
That's why this thread is in place. We need eachothers help to let Suzuki know that there is an obvious problem with this part of the bike.
Hope this helps?
Mass
Old 31-08-05, 02:45 PM   #24
knightster
This happened to me too.
Just rang Paul from Suzuki Customer Services and gave my details.
Old 31-08-05, 04:26 PM   #25
tinceysv650
this has also happened to me, well hasnt happend to me but i did notice it..
the first morning i got the delivery of my bike, i had a good check over the bike and made sure all bolts were tight, i.e if i could rattle it its to loose..
i found that the gear lever was loose and simply tightened it up instead of whyning and bitching about it..
Old 01-09-05, 08:39 AM   #26
Captain Nemo
i dont suppose that you contacted your dealer and asked why they left a major bolt loose then? or perhaps you didnt want to whyne (?) and bitch
to many here this is a mojor issue, please dont take the ****, we are trying to gauge how serious a problem it is , if its not a problem to you then dont troll, ie keep your $h!t to yourself
Old 10-09-05, 01:21 AM   #27
The Basket
This is a serious issue...I will look for it in the morning...If Suzuki don't listen then don't buy a Suzuki...If I find loose nuts then that is an issue...But is this a K5 issue though?
Old 10-09-05, 07:15 PM   #28
The Mass
Yes it's also a K5 issue. Some of the K5 riders on here , have also had this happen to them.
Old 11-09-05, 07:22 AM   #29
The Basket
I have checked my Gear shift and it seems solid enough...I will ask at the first service.
Question...Are you claiming this to be a design flaw or simply a PDI some monkey hasn't put it on properly type thing?
Old 11-09-05, 08:34 AM   #30
The Mass
Trying to make Suzuki aware really, it looks as though they have been playing around with the design of this on different models. Even though it was pointed out by Billy C that the design is the same on all of them, that may be true. But the design of the lever in which it is set in has been changed on most of the models.
So... It would be good if we could geta response from Suzuki.
Cheers anyway
Mass
Gear selector prob stewie SV Talk, Tuning & Tweaking 12 03-04-08 07:57 PM
Gear selector problems gemma1675 SV Talk, Tuning & Tweaking 1 05-09-07 11:49 AM
Gear selector for my Sk1 sexysi SELKENT 4 22-04-05 03:42 PM
Gear change selector zesty SV Talk, Tuning & Tweaking 4 28-03-05 08:36 PM
Help! Where can I get gear selector lever? Thanks. jump SV Talk, Tuning & Tweaking 5 14-03-05 12:17 PM
