#21 | |
when its warm it runs at 1.3k like its supposed to. but then again - its not an SV ![]() |
#22 |
I did take a while getting used to the Ducati having a choke lever after me having an FI SV. Somehow didn't seem right on an injection bike?
#23 |
This issue can be caused by two basic types of disfunction.
1./ mechanical input 2./ Electrical input 1./ can be divided into; a/ throttle body b/cable c/ cam (or the mechanical throttle linkage) 2./ can also be divided into; a/ sensor feeds (water to low for example) b/ sensors (temp & throttle position would be my starting point) c/ wiring ("rubbed" or melted wiring gives incomplete info to the ECU) Although as Sid Squid says, it's probably just a sticky throttle cable. Cheers Mark.
#24 |
Thanks all for your ideas
Tickover a bit high? | krhall | SV Talk, Tuning & Tweaking | 9 | 20-05-08 05:31 PM |
No Tickover | aermacchi | SV Talk, Tuning & Tweaking | 3 | 14-04-08 10:56 AM |
tickover pin | Hazzar | Stuff Wanted | 0 | 09-09-07 04:37 PM |
missfire on tickover | 01 sv650s | SV Talk, Tuning & Tweaking | 1 | 30-03-07 05:48 PM |
Low Oil Pressure at tickover | SteveJWhit | SV Talk, Tuning & Tweaking | 3 | 04-05-05 10:04 AM |
