#21 | |
How do you get a gear from a standstill when you have no clutch. Do you just loose all mechanical sympathy and jam a gear or do you paddle the bike upto 5 mph and jam a gear. How do you stop from stalling. On the SV you have to pull the clutch in to start the bike so you cant turn the bike off, kick it into gear and then use the starter motor to get you going (or can you). Can you do this on any bike??? |
#22 | ||
![]() ![]() Can you do it on any bike? Yes, lighter bikes are easier of course.
#23 |
Cheers Sid looks like I'm doing my changes just fine... I'll leave the downs alone.
#24 | |
Thanks for all the views. I was out today and yes it is smooth and easy once you know the right way to go about it.
#25 | |
#26 | |
to learn the hard way: clutch failed on the M25, so I quickly learned to perform clutchless changes on the hard shoulder, then continued my journey to Heathrow, parked in a multistorey garage, picked up the person I was meeting, and eventually made my way back to Brighton. Never tried clutchless gear changes since that day, neither in a cage nor on my bike. |
Gear change problem-can't get past 2nd gear | muzikill | SV Talk, Tuning & Tweaking | 8 | 14-03-10 10:10 PM |
Clutchless gear changes | Larry | SV Talk, Tuning & Tweaking | 13 | 12-04-07 02:35 AM |
Clutchless Gear Changes? | sweepdoggydog | Bikes - Talk & Issues | 21 | 16-08-05 03:14 PM |
Clutchless up gear changes are jerky-what should I be doing? | thor | SV Talk, Tuning & Tweaking | 8 | 03-06-05 01:51 PM |
