Old 30-03-06, 09:26 PM   #21
Use some sealant on the half moon sections of the cam cover seals.
Old 30-03-06, 10:15 PM   #22
TSM
The Sick Man
TSM's Avatar
What sealant should i use, is there anything special?
All the gaskets came off fine on the chain adjusters realy easly and look in good nick.
Old 02-04-06, 07:24 PM   #23
TSM
The Sick Man
TSM's Avatar
Got it all done, started it and it did not go bang.
I brought nearly all the clearances to bang middle of specified range except the front exhaust, they are within tolarance but still a tad low for my liking. Will have a check of them again at the next service.
Had to do a quick check with SidSquid to just make sure i was reading the Haynes properly but thankfully i had done it all correctly.
It was chugging over when i first started it but it seems to run fine now, well fine as in the way it was before it was off the road. If you give it a handfull of throttle it chokes over then reves up. I think the fueling and balance of the carbs is off a tad.
Old 03-04-06, 07:15 AM   #24
I'm_a_Newbie
Oh the joys of fuel injection!
A job well done. I shall be coming to you for advice in a couple of years when my shims beed checking.
Kind regards
Tim
Old 04-04-06, 01:57 AM   #25
You don; tthink the throttle bodies need balancing, or that the mixtre can be off? The diffference is, changing ht emixture needs a computer and specialist hardware with SV FI, while carbs need a screwdriver
Old 05-04-06, 09:58 AM   #26
wreckah
good going TSM
you almost took as long as my first valve job
it'll go 10 times faster next time (and less headache too )
cheers,
jan
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve Clearances pmapp SV Talk, Tuning & Tweaking 6 23-01-09 01:28 PM
Valve clearances - K3 Lozzo SV Talk, Tuning & Tweaking 1 24-07-08 09:24 AM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
