Old 14-11-07, 01:13 PM   #31
SVeeedy Gonzales
Default Re: Gear changing without the clutch
Not worth the aggro - minimal gains for a lot of risk of screwing up the gearbox when you don't get it right (which happens a lot early on, and especially in the lower gears). You may also find that it goes into a higher gear then drops down into a lower one by not using the clutch, which locks the rear and isn't nice.
If you're dead keen on ditching the clutch buy a thumbshifter. Or a scooter.
Gear Shift Rod bent - Gear Changing problem Thaleshwar SV Talk, Tuning & Tweaking 13 05-06-10 06:28 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
changing gear without the clutch 01 sv650s SV Talk, Tuning & Tweaking 15 13-10-06 06:20 PM
Changing clutch plates on K5 SVs Full Throttle SV Talk, Tuning & Tweaking 7 15-03-06 04:46 PM
Changing Clutch smithers SV Talk, Tuning & Tweaking 8 08-03-06 09:21 AM
