Old 29-05-08, 10:18 AM   #31
Stig
Default Re: Blipping the throttle.
It's all to do with synchronising gears. Matching gear speeds before engaging.
Old 29-05-08, 10:23 AM   #32
Luckypants
Luckypants's Avatar
Originally Posted by neio79 View Post
I have never found a problem with downchanging without blipping on either the ZX6R or my old SV, i dont see as it adds much purpose at all reall, as even if you change down two gears at high speed with a blip if you dont have a slipper clutch the rear will still lock up.
Well not only have you contradicted yourself there, but it is obvious that you were not blipping correctly. The whole point of the blip is to increase engine speed to match the gear speed when you change down. The result will be that rear tyre will not be over braked by the engine as it tries to speed the engine up to the speed to match the gear/wheel speed. If you down change two gears you need to give it more of a blip to get the engine speed higher to match the lower gear.
Old 29-05-08, 10:26 AM   #33
chris8886
chris8886's Avatar
Originally Posted by Steve_God View Post
I do, same reasons.
Although because I to it so often, it's almost become habit and I even do it when going slowly and really don't need to
same for me! although i do find it can be a problem when the engine is really cold as it can cause it to cut out! i do have to admit also that i quite enjoy having there rear end snaking about a bit sometimes. as those who i went to lydden with will testify
AR08 to AR13-QUALITY!
Old 29-05-08, 10:29 AM   #34
ArtyLady
true, I still never found a problem with the smoothness of a change that blipping solved , as if you still cluch up to quick, blip or not the rear wil lock on the SV.
And try as i might the Kwaks rear wont lock
Ive never had the rear wheel lock on the SV (touches wood frantically!) - I must be so damn smooth seriously though - probably because I went through that big time on my Guzzi - what with the shaft drive as well the back end was forever flying out - until I got the hang of it!
Old 29-05-08, 10:29 AM   #35
leatherpatches
The trick is to keep an open mind - try blipping out, even if you think it won't help. You might find that since you last tried it your experience and knowledge of your machine has increased enough to make it worthwhile.
Old 29-05-08, 10:31 AM   #36
ThEGr33k
I tend to blip in low gears cos ive locked skidded the wheel before. But when the revs are high 6K+ just change down and let the slipper clutch cope with it.
Old 29-05-08, 10:33 AM   #37
wyrdness
What about jokes about owning a Harley?
My other bike at the time was a Ducati. Feel free to make jokes about that too
Old 29-05-08, 10:35 AM   #38
ArtyLady
LOL! have a mental image of myself riding along with a calculator and a ruler !
Old 29-05-08, 10:36 AM   #39
Stu
Trinity
Stu's Avatar
Originally Posted by wyrdness View Post
Blipping also helps enormously with slow speed control (ie. when riding at walking pace). .
I've no idea why it works, just that it does. It might be something to do with the gyroscopic effect of the flywheel.
Yes, that's why. Don't try it on a boxer engine like a BMW, as it will push you over
For the avoidance of doubt - The blip is done with the clutch fully pulled in
Well if you're not good enough at it then true I could change down to 1st at about 30 without losing traction (it doesn't actually lock in the first place ) if I match the revs right
Old 29-05-08, 10:41 AM   #40
Stu
Trinity
Stu's Avatar
People, a word of advice, it can come with a bit of practice, don't do what I have seen someone do, blip the throttle but either forget to apply the clutch or let the clutch out to early, it can give you the fright of your life apparently lol. I can blip my throttle for clutchless downchanges now but I have been known to get it wrong also.
That's the only time it catches me out when I try to change down to 1st, but I'm already in 1st & then I can sometimes get a lurch forward as I let out the clutch scary when you are expecting engine braking Anyone got a gear indicator!
Blipping the throttle after changing down a gear. Ruthja2801 Bikes - Talk & Issues 88 25-02-09 02:30 PM
Is there a big disadvantage to not blipping the throttle on fast downchanges? monkey Bikes - Talk & Issues 25 06-04-08 02:43 AM
Braking or Blipping-which is right? Peter Henry Bikes - Talk & Issues 58 27-11-05 09:11 PM
Blipping - eh? Halonic Bikes - Talk & Issues 23 26-04-05 03:56 PM
Ineffective blipping! BaggaZee SV Talk, Tuning & Tweaking 21 27-01-05 10:52 AM
