Old 10-08-09, 12:57 PM   #31
Grinch
Default Re: Valve clearances.
Cool shim... ta.
Old 10-08-09, 05:39 PM   #32
Grinch
Front head Exhaust clearance - 0.15mm (should be 0.20-0.30mm)
Front head Inlet clearance - 0.13mm (should be 0.10-0.20mm)
Rear head Exhaust clearance - 0.15mm (should be 0.20-0.30mm)
Rear head Inlet clearance - 0.14mm (should be 0.10-0.20mm)
Rear shim - 1.26mm (Should be 1.75mm)
Checking the front shim after dinner, expect it will be the same.
Old 10-08-09, 06:22 PM   #33
flymo
flymo's Avatar
thought that it was pretty unusual to see a valve clearance out of tolerance on an SV, let alone all of them. Is it a high mileage engine?
Old 10-08-09, 06:24 PM   #34
Grinch
Oh yes, its done 71k now.
Old 10-08-09, 07:36 PM   #35
Mine made me giggle, 45000-odd miles on it now without a single shim needing changed, which would be decent enough but then, it's had its cams swapped too, and the new cam was so closely toleranced that the clearances were identical afterwards
Old 10-08-09, 09:10 PM   #36
Grinch
Well it looks like I need a shim that 1.20 in size, according to the graph in the Haynes manual. 4 in total.
Old 10-08-09, 09:18 PM   #37
flymo
flymo's Avatar
has it ever needed shimming before or is this a first?
Old 11-08-09, 12:53 AM   #38
jambo
jambo's Avatar
Dan, you've only given 1 inlet and 1 exhaust per cylinder, does this mean the readings for both inlet and both exhaust on front and rear cylinders were exactly the same, or did half the clearances end up in tollerence?
Old 11-08-09, 08:10 AM   #39
Grinch
Yep, sorry both values came out at the same left and right.
Old 11-08-09, 08:12 AM   #40
Grinch
Ah see your working on the assumption that I had looks before, so this is the first time. lol.
Valve clearances - how do you know? SUPERSTARDJ01 Bikes - Talk & Issues 19 09-05-09 05:16 PM
Valve clearances - K3 Lozzo SV Talk, Tuning & Tweaking 1 24-07-08 09:24 AM
Valve Clearances DanAbnormal Bikes - Talk & Issues 31 07-02-08 06:22 PM
Doing the valve clearances... instigator SV Talk, Tuning & Tweaking 7 16-10-06 10:08 PM
Valve Clearances HELP TSM SV Talk, Tuning & Tweaking 25 05-04-06 09:58 AM
