#31 |
Nope, well def wont when it's off or when the clutch isn't pulled in, it'll do nothing at all like that. Faulty, I'm not sure but i guess it wouldn't turn over either.
#32 |
Does it have an immobiliser?
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#33 |
I've got friday off work so I'm going to give the carbs a proper clean out and see if it helps
#34 |
Red Herring, 5hort5 both right as just been out and tried mine. Sorry !
#35 |
What happens if the tank has half a gallon of water in after you have drained the carbs?
The reason I said empty the tank into a bucket is that you can decant the clean petrol off the top of the water & reuse it..... Simples ![]() If you have got water in your tank, check the drain hole at the top of it & also thepipes at the back of the tank under the front seat. I wrote about it here. http://forums.sv650.org/showthread.php?t=111512
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA Last edited by mister c; 01-04-10 at 06:27 AM. |
#36 |
Trinity
If my bike didn't start once, I would not be suspecting half a gallon of water in my tank
![]() After draining water from my carbs for the 2nd or 3rd time, I'd be checking my tank for water. |
#37 |
+1 to choke issues, if the choke is stuck off, it will run like a dream if its been warmed up, even bein in a van with the aircon on for a long drive could get enough warm air in the airbox to fire it up a bit however the first time its sat for a cold night and u try and start it without working chokes you will flood the cylinder and get a big bang when u let off the starter motor probably (also he may have warmed it up before bringin it down to u knowing it had cold start issues as mine can start moderately well off the choke for an hour or two after use still)... i know thats wot happened to mine just before one of my chokes jammed fully on instead
#38 |
wouldnt you take it to a garage ..
#39 |
Trinity
He said it won't start! How would you ride it to a garage?
![]() Surely you would call breakdown recovery first? (I remember hearing of someone whose bike wouldn't start so he had it recovered to a garage for £50 and the garage took a week to fit it in, then charged the battery and handed it back (after charging another £50) This is not a rant at garages being expensive, just a note to do things in the right order) |
#40 |
My bike refused to start when cold and after draining the battery and recharging it 3 times i took carbs off and found the choke plungers were stuck solid so i unstuck them and it started first time with a working choke.
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
Cant get my new Sv650 K5 to start, have i flooded it? | Mej | SV Talk, Tuning & Tweaking | 30 | 09-12-08 08:55 PM |
FIGURED OUT WHY 2006 SV650 WON'T START | LAURENT VALLAT | SV Talk, Tuning & Tweaking | 17 | 04-10-06 02:28 PM |
2006 SV650 WON'T START | LAURENT VALLAT | SV Talk, Tuning & Tweaking | 6 | 02-10-06 08:31 PM |
SV650 won't start - possible battery problem? | B | SV Talk, Tuning & Tweaking | 6 | 08-08-06 07:20 AM |
SV650 won't start | spmorgan | SV Talk, Tuning & Tweaking | 1 | 21-11-04 07:49 PM |
