Old 07-04-10, 10:32 PM   #31
ThEGr33k
Default Re: Datatool System 4 won't disarm.
Use the present indicator connections to fire a relay - low current draw across the exisiting system & nice bright indicators!
Sounds like an idea
Out of interest though where should I power the lights from? Straight off of the battery or?
Old 08-04-10, 08:11 AM   #32
Sounds like an idea
Yes, or whatever convenient battery live is easiest, the live side of the starter solenoid is a common place so you don't need to disturb the wiring when attending to the battery.
You'll need two relays of course, one each for left and right. One terminal of the switch contacts, (30 or 87 on a DIN marked relay), goes to a permanent live, (fused of course, and with the fuse as close to the source as possible), and the other, (87, 30), into the indicator wiring system. Either 85 and 86 go to the indicator output from the alarm and the other to neutral, (earth). Probably a good idea to use a quench diode across the coil in case of inductor spikes - don't know the internals of the System 4, and I'd be surprised if it were susceptible but diodes are cheap insurance.
DIN: 85, 86; winding. 30; wiper. 87; NO. 87a; NC.
Old 08-04-10, 01:40 PM   #33
ThEGr33k
Hmph, well seems I shouldnt need the relay after all but I might do it in the future just for the better performance...
It turns out I bought indicators that should only be put in one way. Sigh. Oh well working now after 3 Fuses so happy. Just have to remember if I need to do anything with them again.
Datatool System 4 Red TSM Bikes - Talk & Issues 47 23-09-21 06:20 AM
Datatool system 3 PIN? nobby SV Talk, Tuning & Tweaking 15 23-03-09 10:17 PM
datatool system 3 evertheoptimist SV Talk, Tuning & Tweaking 17 02-06-08 10:05 PM
Datatool system 3 suzsv650 Bikes - Talk & Issues 1 04-07-07 01:26 PM
Datatool System 3 TSM SV Talk, Tuning & Tweaking 1 16-07-05 11:48 AM
