Old 15-07-12, 12:20 PM   #31
k1ngy SV
Default Re: Charging system help please.
Originally Posted by suzukigt380paul View Post
sounds to me if your battery looses voltage and goes flat after only a few days/hours then youve got a faulty battery,if its only a few months old take it back and get it replaced
My first post-
********Bike info.
sv650s k6
13,000 miles
restricted via ecu.
Dead Battery, thought battery was duff so got new a battery - 3 days later and its dead after doing alot * of miles and various rev's and speeds - checked the green connector which iv seen posted up here before, not burn't out & looks clean & sweet. ***
so my battery isnt even a month old yet, iv also read up that it lose's 1percent of its charge every day . so say its
12.8 volts -> 12.80 <- 100%
00.128<-- 1percent
so therefore it lost 00.20 volts overnight in a cold garage isnt bad going?
on charge again atm, going to take it off and leave it in house overnight to see what it drop's - wish me luck
Old 15-07-12, 01:39 PM   #32
Sy-superfly
Once back on, all charged run the bike and see what voltage appears from the battery terminals, because it can happen the other way around where the alternator over charges. This will kill battery's, so anything like 16v or above will kill the batt. I'd imagine it should be somewhere close to 13.5v maybe 14v. But see what happens first if it drops big time or not in the house.
Old 15-07-12, 04:19 PM   #33
speedyandypandy
around 14-14.5 is normal, I would be worried if the voltage is over 15V on a bike/car since they don't have automatical voltage regulating to compensate for ambient temperature.
Last edited by speedyandypandy; 15-07-12 at 04:28 PM. Reason: Remembered more things from school....
Old 15-07-12, 08:20 PM   #34
suzukigt380paul
Originally Posted by k1ngy SV View Post
My first post-
********Bike info.
sv650s k6
13,000 miles
restricted via ecu.
00.128<-- 1percent
you may loose 1% of volts over night but this shouldn't be repeated every night the bike isnt used,and although you will loose cranking amp after extended periods of not being usedbut the voltage shouldn't drop much below 12 volts after say 2 months, that is aslong you havent got a alarm drawing current,i now have trickle chargers on most of my bikes,but this spring i got my vfr out of hibernation having not being used/started or the battery charged for over 5 months and it started on the battery first time with out trouble,
just checked the voltage on my old gsx600f,dont think its been on the road for 9 months and havent started it this year,no trickle charger,but there is a fuel gauge which is always reading evan when ignition is turn off,and put the meter on the battery and was reading 12.75 volts,the battery is a motorbat gel battery,hope this can give you a indication of what a battery should behave like
Have I fried my Charging System? Destruktor77 Bikes - Talk & Issues 3 24-11-11 10:17 PM
Charging system failure - maybe. Monty SV Talk, Tuning & Tweaking 8 26-06-10 11:12 AM
Charging system question the_lone_wolf Bikes - Talk & Issues 25 31-10-09 07:08 AM
Charging System checking philb SV Talk, Tuning & Tweaking 10 11-06-05 10:29 AM
WTH is going on with this charging system? I know...discusse scarredpelt SV Talk, Tuning & Tweaking 12 01-04-05 01:18 AM
