#31 |
I have a good lever from just bleeding the callipers but I'll remember that trick just in case.
Interestingly what got me curious was a dude on YouTube was bleeding his MC via a nipple, but it was on a trail bike. I'm guessing this is because they generally need more maintenance and the MC is likely to take knocks and end up on it's side a lot which may introduce bubbles.
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#32 |
If you do it right you don't need to bleed the master cylinder - that's why there's no bleed there.
#33 |
#34 | |
#35 |
When I fitted the new caliper assembly yesterday afternoon, it literally took me less than ten minutes, to put the replacement caliper on, refil a completely drained brake system and bleed it.
#36 | |
#37 |
This is what I can't work out, it wasn't a fluke either as I tried re-gaining pressure for 2/3 hours with the old caliper back on and the pistons pushed in (Not that the stuck one ever moved anyway. Its a mystery, I think maybe the seal had gone completely on the piston which came out, hence holding little pressure ...
#38 |
pump them out with a grease gun,never had a piston i couldn't get out,even if they are rusted in solid
#39 | |
If you find something that is thick enough so the pistons can extend most of the way but not drop out, then when you pump the brakes both sets of pistons will extend almost all of the way and stop at the same point. Then remove whatever you were blocking them with, keep pumping and some of them will come out, and whichever ones are left will be easy to remove with a pair of pliers because they will be 90% of the way out already. |
SV650K3 Brake Pistons - where do you get yours? | Longway | Bikes - Talk & Issues | 2 | 17-01-12 06:55 AM |
Best way to clean up brake pistons? | curium | SV Talk, Tuning & Tweaking | 12 | 06-04-09 09:42 PM |
Brake Pistons? | vardypeeps | SV Talk, Tuning & Tweaking | 4 | 29-08-08 12:12 PM |
scaring on brake pistons | huge | SV Talk, Tuning & Tweaking | 2 | 13-01-06 04:32 PM |
new brake pistons and seals. where from? | raymond smith | SV Talk, Tuning & Tweaking | 2 | 30-04-05 09:24 PM |
