Old 07-02-13, 12:03 PM   #31
lawson17
Default Re: Kent cams and Busa pistons.
Now then... Here's an idea... Whether its any good or not?
Keep the kent intake cams in there. As they seem to be right. And put carby intakes in the exhaust side? (I have set in t'garage)
What do you recon?
Old 08-02-13, 07:41 AM   #32
zadar
Originally Posted by lawson17 View Post
It's supposed to be a straight cam swap... The guy I got them from pressed them on for me, as they were fitted to APE sprockets. They have also had a run of mig put on them...
Comparing to the stock cam, this troublesome one is out by 1.5 teeth on the chain wheel. It's almost there by jumping it round 1 tooth. But still not parallel.
The markings / sprockets themselves are identical to the stock ones. Same sprockets fitted to both in and ex on stock cams, just pressed on in different locations. 19F sound about right?
Pressed sprocket on using eyeball?
All 4 sprockets are same, like you said they just pressed in different location.
K3 Engine Fix - Cams, Cylinder heads & Pistons muzikill SV Talk, Tuning & Tweaking 5 27-02-11 05:15 PM
2 x busa pistons and pin's £60 + P&P barwel1992 For Sale - Other Bikes and General biking items 23 13-02-11 11:28 PM
'Busa pistons yorkie_chris SV Talk, Tuning & Tweaking 61 17-02-09 11:07 AM
Renntec sports rack for a curvey and Busa pistons svrash For Sale - SV's and SV related items 0 10-08-07 09:57 AM
Ported and polished heads and a pair of busa pistons svrash For Sale - SV's and SV related items 4 04-05-07 12:50 PM
