Old 21-06-13, 11:04 AM   #31
Mark_h
Mark_h's Avatar
Default Re: Which new tyres?
Another vote for PR3's here too. Also used by a bunch of high-mileage spirited riders I know. Not cheapest but damn good, especially in the wet. Beware though if anything like the PR2's I had before when the front goes off it goes off in a big way as it wears into a strange shape.
Minister for Sustainability
Old 21-06-13, 10:08 PM   #32
savage86
I've got bridgestones bt023's on mine at the moment no complaints good in the dry and wet, have got 5000 out of the rear starting to square off now thats a 80mile round commute on not so windy roads and the odd thrash round the coast roads when i get the chance. Might be able to get a good deal as their being replace with the s20 i think. If you don't do wet then most tyres will be a match for what you need.
Old 21-06-13, 10:16 PM   #33
Red ones
Red ones's Avatar
Metz Z6 here. 11000 miles out of the rear, 22000 miles out of the front.
Sh*t in the winter when it's wet.
Old 22-06-13, 12:43 AM   #34
Vibbentrop
Junior Member
Vibbentrop's Avatar
I ditched the awful factory Dunlops and fitted a pair of Pirelli Diablo Rosso IIs. They are outstanding. They grip like they're glued and give me the confidence to push to the max. Hopefully, being dual-compound, the rear won't square off too quickly.
Vibbentrop is offline   Reply With Quote
Old 22-06-13, 09:19 AM   #35
GHollis
Default Which new tyres?
I would be looking for a tyre that can handle being push when the sun is shining but also when it's very cold give me the confidence to lean it in. Which basically means a good all weather sport touring tyre.
Old 22-06-13, 09:55 AM   #36
muzikill
muzikill's Avatar
Default Re: Re: Which new tyres?
I thought z6's were fine in the wet.
Old 22-06-13, 10:19 AM   #37
Red ones
Red ones's Avatar
With Z6 on I find that if it rains and the temperature is below 5C you and pop the back end out easily and even spin up the rear on the motorway. That said I still buy them and then take it easy.
Old 26-06-13, 05:20 PM   #38
Ajwou
Question: How much would you pay for Michelin Pilot Road fitted?
Old 26-06-13, 06:04 PM   #39
Nutsinatin
Nutsinatin's Avatar
£228 with loose wheels
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 26-06-13, 07:00 PM   #40
Ajwou
Thanks, I wasn't even expecting such a accurate number.
I paid £265 today and I wasn't sure if that's normal price (but they had to take the weels off), so I suppose that's not far from the normal value.
Bike Tyres Leeds - free fitting on Michelin Tyres through Feb & March Paul the 6th Pennine Massive 14 03-03-12 04:59 PM
What Tyres To Put On? Sticky Tyres. SV650R Bikes - Talk & Issues 33 22-10-09 01:50 AM
Tyres again! New tyres to replace stock ones metalmonkey SV Talk, Tuning & Tweaking 12 01-07-08 05:48 AM
Tyres you have... tyres you gettin'? Daz TOTALSV Ireland 6 04-02-05 10:34 PM
Tyres oh tiring tyres 454697819 SV Talk, Tuning & Tweaking 15 13-10-04 08:40 PM
