Old 13-09-13, 01:35 PM   #31
nikon70
Default Re: What RPM for gearchanges?
I am a bit thick sometimes.... can someone draw me a picture on here where I should change gear...
Old 13-09-13, 01:47 PM   #32
Matt-EUC
Default What RPM for gearchanges?
At about the 3 o'clock position.
Old 13-09-13, 01:47 PM   #33
NTECUK
NTECUK's Avatar
Ever seen "Spinal Tap".
Mine goes up to 11
Old 13-09-13, 01:49 PM   #34
nikon70
oh so it's not like the machines you have to try to get it past the red line area then....
my old mini clocks went up to 90mph but the needle went well past that .....
the SV is not like this then.... oh dear, i've been doing it all wrong!
Old 13-09-13, 08:28 PM   #35
a_monkey_hint
Tootling along, anywhere you want. If you're going for your fastest acceleration, personally around 2o'clock. Roughly 9k revs.
Old 14-09-13, 04:04 AM   #36
BanannaMan
BanannaMan's Avatar
Those numbers on the inside of the dial indicate when to change and which gear you should be in.
Obviously you'd want to avoid 12th gear on this bike.
...Bill
Old 14-09-13, 05:36 AM   #37
muzikill
muzikill's Avatar
Doesnt the manual have a rpm guide for gear changes?
Old 14-09-13, 06:29 AM   #38
orose
Yes, but it's very conservative - IIRC, it says to change up in the 4-5k range (good for eco-riding, but not really good for fast progress).
Interestingly, KTM agree with Mark_h, and have put peak power (7-8k) nearly vertical on the SM-T - I'd try it, but 50 in first isn't exactly the most sympathetic approach to riding.
Old 14-09-13, 07:23 AM   #39
NTECUK
NTECUK's Avatar
Last night in the pooring rain i was shiffting @ 7000 rpm.
Thats 1/2 the red line
Old 14-09-13, 08:13 AM   #40
Matt-EUC
Last night on my bandit courtesy bike I was shifting at the redline.
It's a courtesy bike, it's just had an engine rebuild, I'm loosening it up... Honest...
