#31 |
I rode my Cat D write off 60 miles home with a broken arm five years ago, its still going strong (The bike and the arm!)
#32 | |
#33 | |
#34 |
Ok gonna have a look saturday (hopefully, if the seller can do it in the morning). Apart from the obvious of service history and obvious cracks to the frame etc. that I have done for previous vehicle purchases what should I specifically look for. How would I check things like the forks being bent or the headstock being out of line, I don't believe that they would be from the nature of the write-off, but even with the drop in price its a lot of money so want to do everything I can to make sure its a good 'un.
#35 |
Does it ride straight, including hands off? Are the front end and handlebars straight? That is to say; when you're riding in a straight line are the 'bars, top yoke etc all pointing exactly straight ahead?
Does it steer both sides with equal weight? Bear in mind the camber of the road can affect this, so pick a suitable spot before making a final judgement. Sight across the forks perpendicular to the bike - are the chrome sections perfectly aligned? Lie on the floor in front of the bike, line the wheels up - can you see an equal amount of back tyre either side of the front? If it doesn't go straight and steer properly, it's bent, (or at least; misaligned). If it does, it isn't.
#36 |
Bike bought and now sitting outside my flat. Thanks for the advice guys.
#37 |
Wahey, here's hoping it all works outfor you.
Like the bike?
Ain't no sunshine when she's gone... 2000 curvy, yellow and naked. Gone but not forgotten. |
#38 |
Took it for a short spin last night. Its a lot more bike then the SV. It was just up into town, so all very slow and sedate but I can see this will be a mile eater, and still quick enough in the twisties with two of us.
The controls are much lighter and more sensitive, which is the part I found hardest to adjust to. The gearing is a lot longer to, I can happily bimble around town and never change out of first. Only does 4k rpm at 30. Mrs Clunk was somewhat surprised by how much more oomph it had. |
#39 |
Big wide bars dude. Makes it easy peasy. Enjoy!
MotoGoLoco - You knows it The Shed - Suzuki GSX-R 750 K1 | Triumph Tiger 1050 K6 Fallout Bikes (VLogs, Tutorials, Bike Vids) Fallout Breakbeat (My Music) |
#40 | |
Indeed - Mrs Clunk was to avoid falling off the back! ![]() Incidentally - what is the point of grab rails? They seem to do chuff-all to help in my experience, just lull into a false sense of security (which is quickly doused by a smart take-off at the lights) |
