Old 29-05-08, 11:01 AM   #41
ThEGr33k
Default Re: Blipping the throttle.
Originally Posted by Stu View Post
That's the only time it catches me out when I try to change down to 1st, but I'm already in 1st & then I can sometimes get a lurch forward as I let out the clutch scary when you are expecting engine braking Anyone got a gear indicator!
Thats weird. I often try to get 7th gear but I never try to find a 0 gear. How odd. Dont know why I try to get a 7th gear either cos 6th gear is VERY tall. Like 70MPH at 4000 rpm....
Also why would you want First gear at 30mph?2nd is better imo for gunning it.
Old 29-05-08, 11:07 AM   #42
neio79
cos some people bikes can do 86 in first so 30 in first is nothing!!
Old 29-05-08, 11:51 AM   #43
ThEGr33k
Guess some bikes have pussy bottom and mid ranges... Changing gear Pah.
NOTE. Nothing outside of 1000cc Sports bikes do over about 75MPH in first. And no your speedo is not telling the truth if it says other wise... A modern 600 is geared for 65-70MPH depending on model at the limiter. So physically cannot go any faster.
Old 29-05-08, 11:51 AM   #44
gettin2dizzy
I'm always looking for 7th too, although engaging 6th has a certain feel about it so I usually know. I do it in my diesel car by habit I don't understand how people can't do it though, it's instinctive!
Old 29-05-08, 11:54 AM   #45
gettin2dizzy
Balls to that. I've had 86 out of a 07 cbr600rr!
Old 29-05-08, 11:56 AM   #46
Flamin_Squirrel
Well kinda, the revving of the engine bit is but you don't release the clutch whilst doing it. This is due to the difference between car and bike gearboxes. A bike gearbox is 'constant mesh', i.e the gears are always engaged and there is no neutral between gears. On are car you have neutral between the gears and this is the point where you engage the clutch and blip the engine on a car.
The desired outcome is the same, speeding up the engine revs to match the speed of the gear you are changing down to. This allows the gear to engage more smoothly and no jerking / lurching when the clutch is released.
Car gearboxes are constant mesh too, are they not?
Btw, you do go through neutral between gears on a bike.
Old 29-05-08, 12:06 PM   #47
sinbad
Blipping is as much a part of riding any motorcycle as operating the gear lever with your foot is.
Do it right and a downchange to 2nd and 10krpm is as smooth and drama free as simply rolling off the throttle in 2nd after a moment of sustained 10krpm. That's the sort of rev-matching you're looking for when you do it. You could let a slipper clutch deal with it if you want (if you have one) but you're still going to give the rear a moment of greater decelerative load than if you blipped properly.
Old 29-05-08, 12:10 PM   #48
Stu
Trinity
Stu's Avatar
I wondered where those false neutrals came from if that is not true
Old 29-05-08, 12:12 PM   #49
Luckypants
Luckypants's Avatar
Hmmm am I using wrong terminology then? Quick google finds FS to be correct, a car gearbox is indeed a constant mesh gearbox. So what is the correct term for a bike gearbox versus a car (type) 'box? (as I find myself in the odd position of being incorrect! )
I thought the only neutral on a bike was between 1st and 2nd (normally)? But as Stu pointed out, where does false neutral come from?
Old 29-05-08, 12:37 PM   #50
AndyW
Sooo what is all this throttle blipping supposed to be achieving exactly?
If I'm changing down from 5th to 4th I roll off the power as I let in the clutch, shift down, and let out clutch as I roll the power back on. No back wheel lockup, no jerkiness, no bike wanting to get away from me.
Is it only for when you are using very high revs? That doesn't make a lot of sense to me. I'm at 8k revs, shift down a gear wanting to keep same speed, I'm going to be at 10k revs, and the slightest bump in the road that jars you will cause your speed to fluctuate all over the shop as your hand shakes. Maybe on a perfect racing track but for road riding?
Blipping the throttle after changing down a gear. Ruthja2801 Bikes - Talk & Issues 88 25-02-09 02:30 PM
Is there a big disadvantage to not blipping the throttle on fast downchanges? monkey Bikes - Talk & Issues 25 06-04-08 02:43 AM
Braking or Blipping-which is right? Peter Henry Bikes - Talk & Issues 58 27-11-05 09:11 PM
Blipping - eh? Halonic Bikes - Talk & Issues 23 26-04-05 03:56 PM
Ineffective blipping! BaggaZee SV Talk, Tuning & Tweaking 21 27-01-05 10:52 AM
