Old 06-11-11, 11:27 AM   #41
Default Re: Tools - opinion and help needed
Yes the same set I have.
I'd be happy to get by with 1/2", 1/4"... but I'd add a set of allen sockets too as they're really really useful for the bikes.
Old 06-11-11, 11:39 AM   #42
timwilky
timwilky's Avatar
Never one to miss a this is my stuff opportunity.
Toolbox
As I said I have a couple of "sets" although most of my sockets are loose
Top :- 3/4" drive set 19-50mm & 1/2" drive impacts
Middle 1/2" drive Bahco, 3/8 drive Teng, 1/2" drive Britool torx
Bottom Britool 1/2" drive alternator pulley sockets/drive, cheap 1/4" set that is surprisingly useful, Snap on 1/2" drive deep sockets, 3/8" Halford and 3/8 allen bits.
I have a separate toolbox for my imperial spanners/sockets etc.
And yes I have actually used the 50mm socket (to take the drum off a concrete mixer)
Not Grumpy, opinionated.
Old 06-11-11, 12:16 PM   #43
alfa.rbt
impressive kit .I'm just starting to build my kit and also starting to learn stuff
Old 07-11-11, 08:44 PM   #44
alfa.rbt
Originally Posted by alfa.rbt View Post
...Also looking for torque wrench, so which size/sizes do I go for?
Any other essential tools I need to buy?...
Any thoughts anyone???
Old 07-11-11, 09:49 PM   #45
If you're doing chassis work on the bike then 1/2" drive torque wrench, for wheel spindles and such. Most common use really.
Other than that, a 3/8" one, that can go down to 10Nm or below. For lots of stuff in the engine and elsewhere.
Old 08-11-11, 09:08 AM   #46
NTECUK
NTECUK's Avatar
3/8 one, go good quality
1/2 one get one from machine mart good enough.
Old 08-11-11, 09:30 PM   #47
alfa.rbt
cheers
Old 08-11-11, 10:33 PM   #48
NTECUK
NTECUK's Avatar
One of our tecs(Tony) bought one of theses an it passed our iso calibration test !
http://www.machinemart.co.uk/shop/pr...-torque-wrench
This http://www.machinemart.co.uk/shop/pr...ails/040210356 is the modern version of my works one its 20+years old
Old 10-11-11, 12:01 AM   #49
Winder
Winder's Avatar
Can anyone recomend something for getting out very corroded screws from my carbs (screws that hold the choke plunger in place). Don't really want to drill them out and the philips cross head bit is no more as the head of the screws are so soft so can't use my impact driver.
Old 10-11-11, 09:53 AM   #50
Drill it!
Its easier in the long run. Just give everything a soak in penetrating oil also.
Make sure you have a good set of mole grips for the plunger.
Flywheel puller and engine removal tools needed. Mike_84_650S'99 SV Talk, Tuning & Tweaking 2 21-10-11 11:52 PM
air compresser for air tools advice needed barwel1992 Idle Banter 5 03-07-11 04:19 PM
Replacing Clutch - which tools needed? bengodden SV Talk, Tuning & Tweaking 1 01-02-11 12:56 PM
valentines day : blokes opinion needed jenni Idle Banter 30 18-02-07 01:02 AM
any special tools needed for clutch investigation work? grecian9 SV Talk, Tuning & Tweaking 3 22-09-06 03:04 PM
