Old 05-10-13, 08:03 PM   #41
Default Re: She's dead Jim.
no the level of oil in the window when bike is cold should be at the F mark with bike upright. this is why it's best to check oil level when cold.
Old 05-10-13, 08:11 PM   #42
apchara
When its hot, the oil has expanded, and some will be in and around the engine if its very very low when warm and standing it will probqbly be even lower when cold
Old 05-10-13, 08:13 PM   #43
muzikill
muzikill's Avatar
Default Re: Re: She's dead Jim.
Then youve finally cracked it for me. What an idiot I am haha. Cheers bud.
SV dead :o( Gemaroo Bikes - Talk & Issues 19 02-03-10 07:27 PM
Dead 02 SVS 2whelltraveler SV Talk, Tuning & Tweaking 4 12-05-09 01:25 AM
sv k3 dead!!!!! aitch Bikes - Talk & Issues 10 19-06-06 04:57 PM
Dead Can? M65 SV Talk, Tuning & Tweaking 19 09-05-06 12:12 PM
HELP - Dead SV Roy650s SV Talk, Tuning & Tweaking 17 01-03-06 08:37 PM
