Old 14-09-13, 08:53 AM   #41
muzikill
muzikill's Avatar
Default Re: Re: What RPM for gearchanges?
Originally Posted by Matt-EUC View Post
Last night on my bandit courtesy bike I was shifting at the redline.
It's a courtesy bike, it's just had an engine rebuild, I'm loosening it up... Honest...
Thats akin to a role reversal of what mechanics supposedly get up to customers vehicles when they drop them off. If I was the mechanic who had done the rebuild id be fuming lol.
Sent from my GT-I9100 using Tapatalk 4
Old 14-09-13, 09:02 PM   #42
punyXpress
punyXpress's Avatar
Default Re: What RPM for gearchanges?
Originally Posted by nikon70 View Post
I am a bit thick sometimes.... can someone draw me a picture on here where I should change gear...
When the oil light goes out?
Now: Street Triple R
Old 15-09-13, 06:05 AM   #43
nikon70
Running without oil I thought was reserved for Honda engines which can withstand that kind of punishment... Suzuki's tend to be a bit like women and like a bit of lubrication...
