Old 09-02-09, 05:57 PM   #51
Default Re: Sorry to ask but...rear shock?
Which GSXR shock. Spring rates have varied a lot!
Old 09-02-09, 05:58 PM   #52
BBadger
I have checked and cheaked again, others who have riden it say its fine althought they're all about 14st.... it just doesnt want move much and every bump is felt painfuly through the seat.
Old 09-02-09, 06:00 PM   #53
But you have preload on min? What is your sag? If it is bottoming out then it will feel harsh too.
Old 09-02-09, 06:06 PM   #54
BBadger
Right on min .... sag there is only a tiny bit.
Shull crank it up a notch to see if that could make a difference. But still the fact every bump just makes it feel like the shock dont want to move.
Old 09-02-09, 06:07 PM   #55
Try rock the back tyre just off the deck and see how much then.
Has it been lowered or any other such mods?
Old 09-02-09, 06:14 PM   #56
BBadger
Shull give this all a try when im next out in the garage.
None what so ever.
Old 11-02-09, 12:24 PM   #57
stuballs
Bolt in from the other side? Turn base of shock around?
Thought of that but the head of the bolt rubs instead. Maybe I could space the dog bones on that side out with washers. Only need another 1mm.
Old 11-02-09, 04:30 PM   #58
I'd probably grind the bolt head or free end. If it's one of the shocks with the damping adjuster at an angle though you have to have it facing left or you can't adjust it without a small screwdriver and a cold engine!
If you grind bolt then don't let it get too hot.
Old 11-02-09, 04:38 PM   #59
stuballs
Considered that. Was worried that the heat might affect the strength of the nut but if I do it in stages shouldn't be a problem...
Stu
Old 11-02-09, 04:39 PM   #60
Yeah, grind a bit, let it cool. Better to do the head of the bolt than the nut though IMO.
Rear shock 03-08 silent11 For Sale - SV's and SV related items 0 17-05-08 02:53 PM
rear shock nut and bolt for a diff shock drag Stuff Wanted 0 22-04-08 03:52 PM
rear shock socommk23 Bikes - Talk & Issues 1 23-04-07 05:09 PM
Rear shock latts650s SV Talk, Tuning & Tweaking 1 09-08-05 09:17 AM
Rear shock sprocket SV Talk, Tuning & Tweaking 3 17-05-05 10:50 PM
